Old 07-11-2016, 04:38 PM   #1
steve aleve
4L60E Doesnt seem to move the wheels
So I am getting close to test driving my 47-54 3100 on an S10 frame with a 5.3 and 4L60E. I finished up the brakes and the engine starts and idles very nicely. The only thing I am unsure of is that when I jack the truck up and I go from park through the gears, it doesn't make the wheels turn as I would have expected.. For the most part they don't turn at all. They have turned a few times when I try but nothing consistent. Any thoughts? I have the TCC wire to a switch and I have played with that too and nothing...
steve aleve is offline   Reply With Quote
Old 07-11-2016, 05:34 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 4L60E Doesnt seem to move the wheels
ensure you have proper fluid?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-11-2016, 05:38 PM   #3
steve aleve
I will do so tonight. Is this a common problem if there isn't enough fluid or the right type?
Old 07-11-2016, 09:21 PM   #4
Clyde65
Clyde65's Avatar
Not sure if its common but id start there first.
So was it used, rebuilt or ?
Clyde65
Rebuild of Clyde
support our troops!
Old 07-11-2016, 11:17 PM   #5
steve aleve
Used. Hopefully in ok shape but we will see. Thanks clyde65 for the help!!
Old 07-13-2016, 03:14 AM   #6
spectral
spectral's Avatar
if there isn't much fluid in there, the wheels will not turn.
Follow this procedure
http://www.rpmtransmission.mobi/file...lprocedure.pdf
spectral is offline   Reply With Quote
Old 07-13-2016, 07:12 AM   #7
Bigdav160
Bigdav160's Avatar
Your going to need 7-8 quarts in the trans just to get the wheels to turn with no load.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-13-2016, 11:21 AM   #8
steve aleve
Thanks Spectral and Bigdav160 This is helpful stuff!! Spectral, have you attempted the procedure you attached? I don't know why but it sounds nerve racking. Has anyone else done this?
Old 07-13-2016, 08:28 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't understand the whole "run the truck while on a hoist and pull the drain plug"....That sound like a mess and a pain.
Run the truck, put it through PRNDL, and check the fluid level warm. Thats all you need to do. Add fluid as needed. Trans and pan are around 8 quarts, with the converter and cooler its 12-14. If your running a cooler, make sure there isn't a kink or blockage.
Oh and....does the driveshaft turn? IF the DS turns but the wheels don't, we got a different issue.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-14-2016, 02:07 AM   #10
chuychevy82lwb
Front tranny pump could be broken i broke mine when i installed my 4l60e to my 5.3 i didnt seat the converter in all the way
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 07-14-2016, 05:45 AM   #11
spectral
spectral's Avatar
Its not nerve wracking at all. Its not under pressure at idle or anything and hot fluid won't coming spraying out everywhere.
That said, I fill slowly through the dipstick hole on the 4L60E and just keep checking the level until its showing full after everything is up to temp, and I've run through the gears. Saves me getting on my back / under the car as I don't have a hoist.
Old 07-14-2016, 08:21 PM   #12
clinebarger
That procedure is for 6L80E's in car platforms, And other transmissions without dipsticks which is just about everything nowadays.
It's not a drain plug, It's a Check Plug, There is a stand pipe that extends up into the pan at the correct fill level, Sorry.....Off Topic, But the instructions in the link are incorrect for a 4L60E.
clinebarger is offline   Reply With Quote
Old 07-15-2016, 11:36 AM   #13
steve aleve
BR3W City, Thanks for the advice! I checked my fluid level and voila... lol no fluid level. So I plan on filling the trans through the dipstick a bit and keeping it warm to check the levels and I'll see where I go from there. Also, the driveshaft doesnt turn either so I am not thinking it's a rear end issue. Chuychevy82LWB I am hoping that is not the case with mine but we will see.
Old 07-15-2016, 01:01 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Steve, did you check that the gear selector is actually working? You can manually put it into gear from the side of the trans.
Old 07-15-2016, 02:15 PM   #15
steve aleve
I am not sure what you mean? (because I don't know much about this stuff) I have a floor mounted Lokar Shifter on it and I am mechanically moving it through the gears this way. I know that it holds when in park and I have the Neutral Safety Switch hooked up. I think that I am doing what you are saying. Also, I did have a brief bit of movement at the wheels on some of the early startups (when lifted) but I was focused on the engine idling etc and didn't pay much attention to if it was consistent.
Old 07-18-2016, 11:42 AM   #16
steve aleve
So just to let everyone know the results of this. I did read that there was 0 fluid in the transmission so I went ahead and added a quart, ran the engine and shifted through all of the gears. I checked the fluid and added as needed (3 quarts total so far) Once I had fluid in the transmission, the wheels became responsive and I was able to take the truck on my first test drive yesterday!!! It shifted from 1st to 2nd no problem, Neutral, Park, and Reverse all work nicely too!!! Thanks again for everyone's help!!!!
