4x4 operation
Another dumber question. With my 72' K20 4speed what is the proper way to put it in 4wd?
Re: 4x4 operation
Shift shifter, engaged hubs. I believe that'll be an NP205 transfer case in which case no shifts on the fly - need to be standing still. It's possible to leave the hubs engaged when the T-case is in 2WD but not a good idea for long distances.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
So with a manual just have in neutral? Do I have to have the clutch engaged or just not in gear
Posted via Mobile Device |
Re: 4x4 operation
For shifting the transfer case, yes just have the transmission in neutral. The NP205 is practically indestructible, so if you make a little noise with it a couple times don't panic.
Re: 4x4 operation
If you really want to be safe; shut the engine off too. The transfer case has sliding sleeves with no syncromesh devices. As long as nothing is turning, it should slide right into 4x4 mode.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
| Bookmarks |
