Old 10-02-2003, 10:09 PM   #1
lotik
drag it like you stole it
tv cable bracket.
what can i get a bracket off of for a 700r4 to a edelbrock 1406? i know bowtie overdrives sells a kit, but i already have the cable, i just need the bracket. i was hoping to find one in the local scrap yards if possible. basically what i am asking is what vehicle would have a bracket that would work for my application?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-03-2003, 12:16 AM   #2
70 longbed
Lotik,
If you find out, let me know also. What are you using for the cable. I went out to the Bowtie Overdrives site, but did not see the kit. Do you have a part number?
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 10-03-2003, 12:35 AM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I got my bracket off a carburated smallblock that just had bracket that the bolts that attach the intake to head run through. It has a square hole with a little bump on one side. Theres tons of them out there - I've seen many since & they're all the same - just get one with the square hole that will fit your cable & away you go. I'm running a q-jet/700r4 so I cant say exactly what will happen on the carb end BUT i know my bracket works.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-03-2003, 10:59 AM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
I'd recommend spending the extra $$$ on the Bowtie bracket/cable. I had orginally installed a Lokar bracket/cable and the trans shifted like $hit (I also have the Edelbrock). I bought the Bowtie kit and it was like night and day. The problem is that the linkage on the Edelbrock doesn't have enough "throw" to completely move the TV through it's full range. (I personally verified this) Their kit corrects that problem and even allows you to adjust how aggressive you want it to shift. Just my $0.02.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-03-2003, 11:03 AM   #5
70 longbed
Slammed67,
Do you have a part #? I am using the 1406 and 700r4 combination as well, when I get it back together.
Keith
Old 10-03-2003, 12:35 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
Here is a link:
http://www.tvmadeez.com/index2.html
Old 10-03-2003, 12:48 PM   #7
70 longbed
Slammed67,
Thanks for the link. I had already gone out and ordered it this morning, since my earlier request for information. I went back out to the Bowtie site, and found out that they have more than one home page. I just needed to go to the 700r4 page.
Thanks for the help.
Keith
Old 10-03-2003, 02:20 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
When you get the kit, follow the instructions. It'll tell you to take pressure readings in various senarios. You then call them up with the results and they can tell you if everything is working properly. I think you'll be pleased with the kit.
Old 10-03-2003, 04:55 PM   #9
lotik
i think i am going to get the bowtie overdrive kit. it looks well engineered and the information they give about why you should use theirs really makes since.
Old 10-03-2003, 05:24 PM   #10
70 longbed
I am still a week or so from getting that far, but hope to get things back together real soon. It has been so long that I have forgotten how some things go back together; that is going to slow me down some. I relly would like to get it running before I have to go TDY again.
Keith
