07-11-2016, 07:09 PM | #1 |
TH350 to 7R400 swap with 2Jet Carb
Hi,
The 7R400 is now under the truck. Assuming that there is no vacuum modulator on the TH700R4 just the TP cable. What happen to the vacuum line that was there for the TH350. Do I have to keep it open or simply close it? Thanks |
07-12-2016, 12:47 PM | #2 |
Re: TH350 to 7R400 swap with 2Jet Carb
Remove it and cap it at the manifold / carb.
Pretty Vacuum port caps are inexpensive. We (cheap) farmers the pipe out of the hose at the manifold and run in a screw.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
07-12-2016, 04:24 PM | #3 |
Love the screw idea
Thanks for your help |
07-12-2016, 04:54 PM | #4 |
Even better yet, use a golf tee!
