Old 07-12-2016, 11:14 AM   #1
General23cmp
72 door panels, curled corners
Trying to reuse the originals. The clips broke years ago, and the corners are slightly bowed/curled from years of heat and freedom. I can make them straight when bending with my hand, but am unsure if the clips will be able to do it. Has anyone had any luck with that? How about a little heat and persuasion to get back flat?
General23cmp is offline   Reply With Quote
Old 07-12-2016, 12:55 PM   #2
kcsa75
kcsa75's Avatar
Re: 72 door panels, curled corners
If they're not too far out of shape, the plastic clips should hold the panels tight to the door. Classic parts has a whole set for less than $5.
http://www.classicparts.com/1972-Doo.../#.V4UgvKLG940
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
