Old 07-12-2016, 02:32 PM   #1
BigMike56-72
BigMike56-72's Avatar
Spark Plug Help
Guys,
I need some help here. I just picked up a 72 with a 350 in it and I want to change out the plugs. It currently has some SplitFire SF2E plugs installed but when I look up online they are discontinued. I want to get new plugs that are as good or better than what it had installed. There are so many options to choose from and I don't want to order the wrong thing. Any mechanics on here that can point me in the right direction?
Also I have a question on oil weight. The mileage on this truck are really unknown at this time, so with that being said what weight oil would you use?
Again thanks again for your help.
Mike
BigMike56-72 is offline   Reply With Quote
Old 07-12-2016, 06:00 PM   #2
trac209
Re: Spark Plug Help
AC delco 45ts or equivalent will be fine for plugs and a decent 10/30 weight oil will be good enough for a stock engine in good working order.
trac209 is offline   Reply With Quote
Old 07-13-2016, 10:36 AM   #3
BigMike56-72
Re: Spark Plug Help
Trac209
Thank you for the info. I went to the auto parts store and they gave me some AC R43TS. I could not find 45TS plugs. Would these be OK?
Old 07-13-2016, 10:55 AM   #4
LONGHORN1962
LONGHORN1962's Avatar
Re: Spark Plug Help
43's are a little colder plug. If you can't fine 45 go 46 but no hotter, unless it burns oil.
LONGHORN1962 is offline   Reply With Quote
Old 07-13-2016, 11:15 AM   #5
GRX
GRX's Avatar
Re: Spark Plug Help
At this point I will mention to make sure you get the right type plug. The seat was switched from gasket type to taper around this time. And you never know what has been done to a 44 year old truck.
GRX is offline   Reply With Quote
Old 07-13-2016, 11:27 AM   #6
BigMike56-72
Re: Spark Plug Help
I agree that is what has me stumped and why I am so worried on getting the correct plug that is a direct replacement for the Split Fire SF2E. I am guessing if I find a direct replacement it will be correct. Not sure if this plug is tapered or not.
Old 07-13-2016, 11:31 AM   #7
BigMike56-72
Re: Spark Plug Help
Here is what one of the plugs looks like. The truck has been sitting for 7 years.
Old 07-13-2016, 01:53 PM   #8
GRX
GRX's Avatar
Re: Spark Plug Help
Tapered plugs. No metal gasket. Good to go.
Old 07-13-2016, 06:48 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Spark Plug Help
Stock points ignition or HEI conversion?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
