Old 07-12-2016, 02:54 PM   #1
dflarsen77
Active Member
Charcoal Canister with no purge?
I'm doing a vent line on my truck, and I need to replace my charcoal canister, because it has a hole in the side, top is broken & pitted from battery acid.
Anyways, so I went to the junkyard and picked up this unit of an 80's GMC 1/2 ton:
I grabbed it because I was in a bit of a hurry, it's the right size, and it has 2 lines which is all I need. Originally, the cans had 1 valve coming from the tank, 1 valve from the carb vent bowl (no longer need since it has an edelbrock now), and 1 to the PCV to suck the fumes out. But this one just has 2 lines, labeled "tank" and "carb". So I'm trying to find online if one of these is a purge valve, with no success. It was used on a bunch of cars and trucks, but I have yet to see a PCV diagram for one showing how it's hooked up. It doesn't seem like it would work if it was just the fumes from the tank & carb just go in there to sit. They have to go somewhere. I'll be going back to look for another, but if this one works, it would be great.
dflarsen77 is offline   Reply With Quote
