Who Me?
AC Leak Test
I have a general AC question. I have a set of gauges and a RobinAir Vacuum pump. I can pull the system down to 29PSI of vacuum, but over the last 2 hours, it has lost 2psi of vacuum.
Im not sure if this is an accurate test. The gauge valves are closed, but the gauge lines are still in play. I had a leak and believe I have it fixed now, but wanted to try and test it before dumping freon in it. Is there a better way to test the system with out freon? Thanks for any advise.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
blood type; Retumbo
Re: AC Leak Test
I'd charge it now and add 1/4 ounce of tracer dye. I dont get too worried about a 2" drop, that could be a gauge issue
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#3 | |
Who Me?
Re: AC Leak Test
Thanks for the help.
| Bookmarks |
