tilt column not tilting
Anyone have any ideas on why a tilt would not tilt.. its stuck in the lowest position for some reason. I'm prepared to tear it apart if necessary. Just gottas browse up on how ...LOL. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
I had that happen a few years back on a 72 Highlander I had and I removed the wheel, spraied "brake clean" down the shaft. almost 1/2 a can. Then it actually freed up everything. Then I hit it with wd-40 and it was good as new. Im not sure if it was the same problem as yours, but it worked for me and it worked great. I felt I had nothing to loose as I was ready to pull the complete thing apart anyway so I went for it!
Good luck. |
I lubed it up today but got impatient and took it apart anyway... and it works now... it was just loaded with debris and rust. Rod
