Old 07-13-2016, 11:03 AM   #1
mxer666
Bed angle strips
When replacing strips, how do you guys attach them?
mxer666 is offline   Reply With Quote
Old 07-13-2016, 11:54 AM   #2
Coupeguy2001
Coupeguy2001's Avatar
Re: Bed angle strips
three ways,
1. spot weld them back on
2. small round head screws
3. rivets, like airplane type, not pop rivets.
Coupeguy2001 is offline   Reply With Quote
Old 07-13-2016, 11:57 AM   #3
mxer666
Thank you.
Want to not burn 66 y.o. patina, screws or rivets will be the way
Old 07-13-2016, 12:10 PM   #4
Tomb23
MAR-K makes angle covers in polished stainless,
unpolished stainless and steel, just like angle strips
Tomb23 is offline   Reply With Quote
Old 07-13-2016, 03:44 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Instead of welding and If you want the bolts hidden from the outside most people put the end bolts in the stake pocket and the center bolts inside the wheel well..
Old 07-13-2016, 07:16 PM   #6
mxer666
I like that idea.
thanks
Old 07-13-2016, 07:45 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
Good timing on this thread. I literally delivered my new polished angle strips to the body shop today!
They will be bolted to the bed sides using the "mongocanfly" approach above. I instructed the body guy to make sure the bolts that go into where the fenders will hide them are in line with the regular board strip bolt heads. It'd look weird to me otherwise.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-15-2016, 11:13 PM   #8
roger55
roger55's Avatar
I used #10 stainless button head screws.
I spaced them evenly and for the ones that were visible from behind, I used stainless acorn nuts.
roger55 is offline   Reply With Quote
