07-13-2016, 03:09 PM | #1 |
clutch rod
I am in need of a clutch rod for a 1969 c10 truck with a 250 cu in motor and a three speed transmission.It mounts from the side of the motor to the transmission fork. The V8 clutch rod will not work.
07-13-2016, 03:43 PM | #2 |
Re: clutch rod
I think the part you're looking for is what we call the "Z-Bar". Yes, the L6 and V8 Z-Bars are different, the L6 is wider. It's a 1-1/4'' tube with two arms at different angles. The arms connect to the Upper and Lower Clutch Rods.
The Upper Clutch Rods are also different between V8/L6. The V8 one has a pronounced dog leg, the L6 isn't straight either, just not as angled.
07-13-2016, 05:27 PM | #3 |
Re: clutch rod
I am looking for the lower clutch rod.
07-13-2016, 09:18 PM | #4 |
Re: clutch rod
Try LMC p/n 32-6113.
www.lmctruck.com
