Old 07-13-2016, 05:31 PM   #1
curvedglass
curvedglass's Avatar
Radiator upgrade
The radiator is starting to go out on my 63. I am running a 230 3 speed on the column. My future plans are for a good wrench 350 ( or facsimile of ). I plan on having the radiator recored at a local shop in town. how many rows do I need for a V-8 ?
--Life looks better through a curved windshield--
curvedglass is offline   Reply With Quote
Old 07-13-2016, 10:53 PM   #2
lumpy63
lumpy63's Avatar
Re: Radiator upgrade
a 3 row should work no problem with a good wrench or similar 350 , if you plan on running ac get a 4 row.
lumpy63 is offline   Reply With Quote
Old 07-14-2016, 12:42 AM   #3
Captainfab
60-66 Nut
Along with the radiator, you will need a shroud and a good fan. If you go with the long water pump as so many do, be sure to get the fan positioned correctly into the shroud. Most long water pump users have the fan too far into the shroud.
Old 07-23-2016, 05:19 PM   #4
SparkyRnD
SparkyRnD's Avatar
We also make radiators here in the USA using domestically sourced materials by hand to fit your truck (and we can put the inlet / outlet wherever you need at no additional charge). They are all tig welded, no epoxy or glue either. Plus, we are a site sponsor. Let me know if you are interested.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 07-23-2016, 08:14 PM   #5
oliver63
oliver63's Avatar
On your crossflow for a '63 can the inlet be on drivers side? I noticed on your website it was located on the right side. Do you give forum members discounts?
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline   Reply With Quote
Old 07-23-2016, 08:46 PM   #6
60chevyjim
60chevyjim's Avatar
you can get nice aluminum radiators on ebay for our trucks 60-66 .
I have seen some for really great prices on them on there ..
around $150. including the shipping ..
60chevyjim is offline   Reply With Quote
Old 07-23-2016, 09:02 PM   #7
SparkyRnD
SparkyRnD's Avatar
Yes, we do offer forum discount ($25 on the radiator, $20 off fan & shroud kit), and yes we can put the inlet / outlet wherever you need them at no additional cost.
True, but most of those are chinese built-units that are cheap, using cheap materials and epoxy / glue to hold them together. Most don't last more than a year. We build ours here in the USA using domestically sourced materials, and they are MUCH higher quality. You do get what you pay for, and changing a radiator isn't something most people want to (or can afford to) change every 1-1.5 years. I do understand though that ours are more expensive than that, but an American made unit will inherently cost more for the better quality.
Old 07-24-2016, 07:38 AM   #8
oliver63
oliver63's Avatar
Thanks Sparky...I will call tomorrow. Who should I ask for?
1996 K2500
Old 07-24-2016, 08:25 AM   #9
SparkyRnD
SparkyRnD's Avatar
Pm me your number and name and I can call you mid-day tomorrow
Old 07-24-2016, 04:06 PM   #10
60chevyjim
60chevyjim's Avatar
I put a ebay all aluminum rad in my 51 chevy 4 years ago for $130 including shipping .
its all welded and works great .
buy what you can afford as long as it is all aluminum and welded .
with my limited income I have to find the best item for the best price .
Old 07-25-2016, 06:11 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Thats what I put in my 61 and had no issues with it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-25-2016, 07:54 PM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used Champion Radiators, haven't had an issue with mine or the one that is in my dads crew cab.
If I were building it today I would use one of Sparky's since I like to use board vendors when I can. Also they would move the inlet and most wont.
Even if it seems like more money, its worth it to me to support folks that are building and supplying us truck enthusiasts.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-25-2016, 09:16 PM   #13
oliver63
oliver63's Avatar
I ordered my today from Sparky...he was very friendly and helpful. Thank you Sparky!
1996 K2500
Old 07-26-2016, 02:18 AM   #14
Bart Savage
Bart Savage's Avatar
i had my stock unit rebuilt for my ls swap with neck and steam port on passenger side for 525$. fits perfect and looks right.
Bart Savage is offline   Reply With Quote
Old 07-26-2016, 09:43 AM   #15
SparkyRnD
SparkyRnD's Avatar
Thanks for the support guys, we do appreciate it. Even though it is more money than the cheap chinese units and the Champion units, you do get a better quality radiator from us. Most of the lesser expensive units use epoxy or glue (typically at the core), while we don't. They also tend to have less-clean looking tanks with more welded sections, while we try to keep ours as clean / nice looking as possible. But with that said, I completely understand that our set up is outside of some folks budget.
