Old 07-13-2016, 09:12 PM   #1
Lunnb
64-66 radiator
Any suggestions for a radiator for a 64 c10 , 350 / 350 ? The existing radiator is not stock , no longer usable , just looking for something affordable that will fit and handle the cooling .
Thanks !
Lunnb is offline   Reply With Quote
Old 07-13-2016, 10:46 PM   #2
zach_carver
zach_carver's Avatar
Re: 64-66 radiator
I'm using a aluminum champion radiator in my C10. Seems to be doing very well for last couple years
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 07-13-2016, 10:56 PM   #3
roll_the_dice
roll_the_dice's Avatar
Re: 64-66 radiator
I am in the same dilemma, but I also want one made in the USA, so I am going to go with www.rndfabrication.com. Not the cheapest if you get the electric fan kit, but made in the USA and for $420 for just the radiator isn't horrible, I just can't justify anything else.
roll_the_dice is offline   Reply With Quote
Old 07-13-2016, 11:01 PM   #4
AcampoDave
AcampoDave's Avatar
Re: 64-66 radiator
Here's what I use. I give it 2 thumbs up https://www.speedcooling.com/1963_19..._Radiator.html
AcampoDave is offline   Reply With Quote
Old 07-14-2016, 07:24 AM   #5
corvettejim1968
corvettejim1968's Avatar
Re: 64-66 radiator
Champion 4 core. with a new shroud and electric fan. purchased at So-Cal
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 07-15-2016, 11:04 PM   #6
grubsster
grubsster's Avatar
Re: 64-66 radiator
Corvette Jim. I recently purchased the same radiator. What did you have to do to make it fit? the radiator tank is considerably wider than the saddle clamps. Yours looks like a perfect fit.
grubsster is offline   Reply With Quote
Old 07-16-2016, 07:08 AM   #7
corvettejim1968
Re: 64-66 radiator
i cut the saddle clamps in half and moved one end out an inch. worked perfect
Old 07-23-2016, 05:18 PM   #8
SparkyRnD
SparkyRnD's Avatar
Re: 64-66 radiator
We appreciate the support, thanks!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
