Old 07-13-2016, 11:02 PM   #1
sherm6413
Brake problem...is it my master cylinder or booster?
I just put all new brakes on my 69 swb and 5 lug setup and booster/master cylinder from 72. So i have disk front drum back with all new lines. no junction leaks no wheel cylinder leaks , NO LEAKS AT ALL. the fluid level isn't dropping at all either. I thought they were good after i bled them numerous times and seemed to have a decent pedal. Now i have hardly any pedal pressure when pump and then if trying to hold it down it just loses all pressure and fades down-the pedal that is.. I'm assuming brake booster or master cylinder is my only options left to be the problem...This all happened after my brakes which i thought were good suddenly went to the floor completely while backing out garage and i hit my other truck......
what do you guys think?
sherm6413 is offline   Reply With Quote
Old 07-14-2016, 12:10 AM   #2
lovemy71s
lovemy71s's Avatar
Re: Brake problem...is it my master cylinder or booster?
Sounds like a master cylinder to me.
71 GMC 1-2 ton 4x4
71 Chevy Cheyenne 2wd
lovemy71s is offline   Reply With Quote
Old 07-14-2016, 12:44 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Definitely the first option. In addition to just a bad MC, I hear the rod needs to be the correct length.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-14-2016, 11:53 AM   #4
sherm6413
Thanks guys, what I thought too.. guess ill try a new m.c. first
Old 07-14-2016, 04:26 PM   #5
sherm6413
spot on, you guys are the best --I have brake out of this world now with a brand new bench bled master cylinder!!
Old 07-14-2016, 11:08 PM   #6
sbrban
I'm having the same issue with my Jimmy...it's on the list for the weekend!
you never have too many suburbans....
sbrban is offline   Reply With Quote
