Old 07-14-2016, 01:18 AM   #1
UKNOWME
UKNOWME's Avatar
C30 frame/bed variance?
Was there such a thing as a cab and chassis build? If so will a regular dually bed bolt up? I'm looking for a c30 regular cab dually to build. I find many without beds. If I know the frame length is the same maybe I can buy the bed separately. Thanks for the help!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-14-2016, 01:47 AM   #2
andrewmp6
Re: C30 frame/bed variance?
If i remember right the frame is not the shaped the same but some have made a pickup bed work.
andrewmp6 is offline   Reply With Quote
Old 07-14-2016, 06:21 AM   #3
GM72K10
Next!
GM72K10's Avatar
Frame Length is not the same, different wheel base unless you ordered a Pickup with "box delete". Pickup is model 30903, 131.5" wheel base, C&C is either 135.5 (31003) or 159.5" (31403)
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 07-14-2016, 09:28 AM   #4
CSHADES
CSHADES's Avatar
If I remember correctly the rear axle is also different between a cab/chassis and a pickup with a factory box
CSHADES is offline   Reply With Quote
Old 07-15-2016, 02:20 AM   #5
andrewmp6
The dually axle c&c is a lot more narrow then a pickup one.
Old 07-15-2016, 02:56 PM   #6
UKNOWME
UKNOWME's Avatar
Hopefully most of these someone removed the factory bed and installed a flatbed. Guess I'll check closer if/when I find one I like.
1964 Chevy c10
Old 07-16-2016, 02:49 AM   #7
andrewmp6
If i remember right a cab and chassis frame from under the cab back is straight where the pickup frame curved up a little behide the cab up to the bed.
Old 07-16-2016, 09:45 AM   #8
UKNOWME
UKNOWME's Avatar
If that's correct that would sure make it easy to distinguish
1964 Chevy c10
Old 07-16-2016, 06:37 PM   #9
GM72K10
Next!
GM72K10's Avatar
Frames aren't THAT different, mostly length and spring hanger location
86 K30 CUCV M1028A1
