Old 07-14-2016, 10:05 AM   #1
Marshy
Air vent on driver side?
My '84 does not have an air vent on the driver side by my left foot. Matter of fact there is nothing there at all. There is an open hole which looks like its for a manual vent like on the passenger side but I'm not quite sure if the driver side should have a vent at all. Can anyone confirm? LMC does not list a vent for the divers side. What belongs there?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 07-14-2016, 01:56 PM   #2
TKCR
TKCR's Avatar
Re: Air vent on driver side?
There is no vent on the left floor area
TKCR is online now   Reply With Quote
Old 07-14-2016, 02:00 PM   #3
Marshy
Should there be a panel there? Pics?
Vortec Engine Build
Old 07-14-2016, 02:28 PM   #4
TKCR
TKCR's Avatar
I found an old photo of when i was in the process of changing from maroon to grey. The panel I believe you are referring to is down under the dash, right there by the parking brake pedal.
From LMC, it's part #1 of the Air Vent Components. As you can see, the right side is made for a vent, but the left side is not.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=94
Old 07-14-2016, 03:06 PM   #5
Marshy
You are correct, its down by the E brake pedal. I guess I assumed that there might have been a vent for the LH side for trucks without AC as that panel is listed under models with AC...
Thanks!
Vortec Engine Build
Old 07-14-2016, 04:50 PM   #6
Wgesnerjr
Wgesnerjr's Avatar
On earlier year trucks, there was an opening if it was a non-A/C vehicle. WE had an old 78 that had the hole. But for some reason, GM decided to do away with it in the later years.
I'm kinda bummed because my cab has a little rust spot. It's inside the cowl cavity near the seem by the E-brake pedal. The E-brake side looks deceivingly good and you can only see the spot if I use a scope. (which I did to make sure all was ok up there.) This whole thing would have been much easier to see and treat if GM left the hole there, dang it!
Since there is no way to get my hand in there from the top or the bottom, my plan is to pour a small can of POR15 down from the top and hope is covers the small rust spot.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-14-2016, 10:38 PM   #7
Rollin86
Rollin86's Avatar
That's very strange, my 86 has no A/C but I do have the driver vent
Rollin86 is offline   Reply With Quote
Old 07-14-2016, 10:41 PM   #8
Marshy
Think you could post me a pic?
Vortec Engine Build
Old 07-14-2016, 10:44 PM   #9
Rollin86
Rollin86's Avatar
Once I get the truck back from the upholstery shop I will. I was just thinking about walking outside and snapping it but reliable I don't have my truck. ;( any day I'll have it back
Old 07-14-2016, 11:29 PM   #10
rigon4
rigon4's Avatar
Non ac trucks have the air vents, ac trucks use the passenger side vent to draw air from and there is no vent hole on driver side
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 07-15-2016, 10:12 PM   #11
Marshy
So I took a look and found that I have a panel there but I can see it's not the correct one. There's some left over gasket around the hole where the vent should be.
Vortec Engine Build
Old 07-21-2016, 07:23 PM   #12
Rollin86
Rollin86's Avatar
Just picked up the truck from the upholstery shop, here's the panel from my 86 step side non-Ac.
Old 07-21-2016, 07:25 PM   #13
Rollin86
Rollin86's Avatar
I can't figure out with my cellphone posting photos, multiple at the same time.
Old 07-21-2016, 08:22 PM   #14
Marshy
Awesome, thanks man. Now I just need to find one. Lmc doesn't seem to have one.
Vortec Engine Build
Old 07-21-2016, 10:30 PM   #15
Rollin86
Rollin86's Avatar
Brothers sells it. Part number PKP87NL 73-91 kick panel, full cover, left without A/C $34.99
Old 07-21-2016, 10:51 PM   #16
Marshy
Thanks! Their site isn't very user friendly on mobile... I'll finds it though.
Vortec Engine Build
Old 07-21-2016, 10:53 PM   #17
Rollin86
Rollin86's Avatar
Just got there catalog in the mail today! And agreed about there website. I do believe I've seen same panel from LMC too
Old 07-21-2016, 11:23 PM   #18
Marshy
Found it...
https://www.brotherstrucks.com/mobil.../products/549/
They still don't look like the one you pictured though...
Vortec Engine Build
Old 07-23-2016, 01:12 PM   #19
v30crewcab
v30crewcab's Avatar
my 88 crew has a drivers vent. no factory ac originally.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
