07-14-2016, 02:52 PM | #1 |
Question for those with front disc and rear drum.
If you have disc front and drum rear, what hard line are you running to the rear wheel cylinders? 1/4" or 3/16"?
I'm about to plumb new hard line. I'm keeping my original 1965 rear drums. I'm nearly 100% sure my rear drums have the stock setup with 3/16" hard line running back from the common 1/4" front drum line. Has anyone switched their rear drums to 1/4" line? My new front disc brakes will be 3/16" line. The MC uses a 1/4" line for the rear brakes and I was thinking of switching the rear drums to 1/4".
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
07-14-2016, 04:06 PM | #2 |
Re: Question for those with front disc and rear drum.
I did factory replacement lines down the frame and on the axle and they are 1/4" on the frame and 3/16" from the tee fitting to the wheel cylinders. I'm running a 1" Wilwood master, 1/4" to the front calipers as well and seems to have good pedal thus far. I'll find out for real when I get it on the road soon
07-14-2016, 08:51 PM | #3 |
I have the 96 blazer set up and I'm 1/4 to 3/16 in the rear...3/16 to 3/16 split to front...worked great
07-14-2016, 08:54 PM | #4 |
By the way Lugnutz I'm dropping my T 5 in next week...the clutch is in..thank you your blog helped me a ton!
07-14-2016, 09:05 PM | #5 |
Moderator
My 65 was 3/16 from the front to all the way to the back. Don't think it will make a difference once you start swapping components. Just make sure you have your lines connected correctly.
07-15-2016, 12:07 AM | #6 |
1961 GMC - I'm in the process of doing disc conversion on the front, keeping the drums in the rear. I have figured: 3/16 to the front discs, 1/4 from proportioning valve to rear brake hose, then 3/16 to wheel cylinders. Strange thing is, I ordered replacement rear axle brake lines from Classic Industries, and they sent 1/4", which does not fit. Waiting to hear from customer service.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
07-15-2016, 01:47 PM | #7 | |||||
So I'm really only concerned about the rear brake line circuit. I'm concerned that if I use 3/16" line in the circuit with a PV that was intended to only have 1/4" line, then the PV will not likely function as well as it should.
07-15-2016, 02:58 PM | #8 |
Interesting point, I agree 3/16 line anywhere in the circuit makes it like all 3/16 line. I'm not sure why the line going to the rear is 1/4, and then the rear axle line in 3/16. I'm using the proportioning valve out of a 1979 K-10, anyone know what diameter the rear axle line is in those trucks?
07-15-2016, 05:39 PM | #9 |
For a frame of reference, I found that 65 used 3/16" lines while 66 was upped to 1/4". I bought the full brake line kit for the truck and set it up to work with the manual Wilwood master. I don't remember any adapters into the front hoses for the CPP disc brake setup but I did buy adapters, 3/8-24 male to 7/16-20 female, for a few other places in the system.
07-15-2016, 10:51 PM | #10 |
I'm running 1/4" down the frame to the rear brake hose, then 3/16" from the tee on the axle to the wheel cylinders.
07-16-2016, 01:59 AM | #11 | |
Found this post over on the square body forums. It appears that those trucks had 1/4 line splitting into 3/16 for the rear. So, if using a proportioning valve made for a square body truck, should be golden.
07-16-2016, 09:47 PM | #12 |
Just an update for those who are following this thread.
I went to the salvage yard today and confirmed a few things about the 1995 Blazer brakes. The Blazer uses a 1/4" line from the MC to the PV and then to the antilock mechanism box. Then more 1/4" line along the frame rail to the rear brake hose. Then it changes to 3/16" from the brake hose to the rear drums. The Blazer front brake circuit is all 3/16". Why all the fuss? Well I just wanted to make sure the Blazer PV would function properly since I plan to keep my 3/16" brake lines that are currently on my 1965 C10.
