Old 07-14-2016, 05:53 PM   #1
In The Ten Ring
Windshield washer pump question
I bought a replacement washer fluid pump at O'Reilly's last month. Does it matter which way the unit is oriented? Each pic I've seen on this forum has it with the intake nozzle down.....will it work with the intake nozzle orientated upwards?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 07-16-2016, 02:30 AM   #2
In The Ten Ring
Re: Windshield washer pump question
ttt
Old 07-16-2016, 09:14 AM   #3
BLT gmc
I believe the little electric pumps will work with the intake up or down in orientation. Take care, Bruce
BLT gmc is offline   Reply With Quote
Old 07-16-2016, 09:32 AM   #4
Grumpy old man
Grumpy old man's Avatar
It's faced down to avoid air accumulation in the lines .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-16-2016, 01:02 PM   #5
In The Ten Ring
Could be a big annoyance....could you explain how air accumulates in the lines if the pump is pointed the way I have proposed? *Not being smart, I really want to know.
