07-14-2016, 07:55 PM | #1 |
Old member
56 Chevy
A little off topic here guy's but my dad is fixing to buy this car. We are going to look at it next week and if he likes it as much in person as he does by the pictures he is buying it.
I have a couple of questions though. The motor as you can see is a 96 LT-1 along with the 4l60E. Can I add the electric cruise control like I did in my truck to it? I also have herd bad things about the distributor on these motors. Anything I need to be concerned with. Anything else I need to look for. Thanks
07-14-2016, 08:14 PM | #2 |
Re: 56 Chevy
You might want to google "LT1 optispark" to learn more about the problems and solutions. I think GM improved them in 1995.
First thing I'd do is get fresh air into the throttle body from somewhere other than the radiator fan!
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-14-2016, 08:58 PM | #3 | |
Old member
Re: 56 Chevy
The first major thing is adding AC but I've already got that covered I hope.
07-15-2016, 04:40 AM | #4 |
Re: 56 Chevy
The older opti-spark was a bad design, but like the other guy said, they improved them in the later years, although I still dont think they were fool proof.
As for the cruise control, yes, you can add it just like on your truck, the LT1 PCM will put out the same 4000ppm signal that the cruise module needs.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-15-2016, 05:42 AM | #5 | |
Old member
Re: 56 Chevy
Thanks ls1nova71, I was hoping you would make a post. I was going to message you if you didn't. The guy that has the car is a friend of mine and he says it's never gave him problems. The car only has 5000 miles on it since the motor and trans has been put in. So I can buy the same module that I got from you then and wire the same way and get a turn signal switch like the one you sent me. Can you post the year model modules I can use please again. What year turn signal switch also if you know of any. Thanks bunches.
07-19-2016, 06:59 PM | #6 |
Old member
Re: 56 Chevy
Going this Saturday to look at it and make a offer. Hope to be driving it back home!
07-23-2016, 10:46 PM | #7 |
Old member
Re: 56 Chevy
Well we drove it home today! Car ran great. No problems and it's clean and rust free. It's been garage kept for over 40 years. It's basically all Original inside and out.
The motor and transmission are newer (LT-1/4L60) along with full SS exshaust system with ceramic coated headers. car has some paint issues but dad is going to drive it so those will be took care of at a later date. AC, cruise, cold air intake and electric wipers are the first mods and upgrades we need to get done. That picture is worth everything to me. Dad has even named her already: MzEDNA after my mom.
07-23-2016, 11:57 PM | #8 |
Re: 56 Chevy
Nice Shoebox!!
Just so you know, You can get rid of the opti-spark & run a LS PCM & "COP" Ignition, It being a '96 LT1 with a Crank Trigger makes it all that much easier. https://www.eficonnection.com/home/p...-wo-ckp-sensor Then all you need is a Harness, Custom tuned "0411" PCM, Coil Brackets & Coils. If you keep the opti-spark.....Make SURE it is vented correctly, One hose goes too a Vacuum source, The other goes too the intake elbow (Fresh air), Moisture kills these distributors! If you do end up having too replace it, ONLY use the latest GM distributor.....https://www.summitracing.com/parts/ado-19212300 |
07-24-2016, 02:10 AM | #9 |
meowMEOWmeowMEOW
Re: 56 Chevy
Cop Shocks, Cop Motor....
I couldn't resist a bad Blues Brothers entendre
07-24-2016, 06:02 PM | #10 | |
Old member
Re: 56 Chevy
I think we will leave it as is for now and see how it does. Dad want drive it much I don't think.
07-24-2016, 09:20 PM | #11 |
Re: 56 Chevy
Your welcome, Just check on the vents!
I would consider installing a factory deep pan on the 4L60E, A new GM pan is dirt cheap, https://www.amazon.com/ACDelco-24240...ype=automotive And you need a matching Filter......https://www.amazon.com/ACDelco-24208...nsmission++pan |
07-25-2016, 02:47 AM | #12 |
Old member
Re: 56 Chevy
Will do, thanks!
