Old 07-15-2016, 09:48 AM   #1
scoot_mcgrute
Steering Wheel Pictures
Hey Guys,
I've been tossing around the idea of getting a new steering wheel for my 66. I like the look of original one but with the power rack and pinion steering, a wheel that large isn't needed anymore. I'd like something a little smaller and maybe with less of a dish to get the wheel closer to the dash.
What have you guys swapped to in your trucks with power steering? Got any pictures?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 07-15-2016, 10:12 AM   #2
Re: Steering Wheel Pictures
I went period correct sorta, and got a repop GM comfort grip wheel used in the 1st get Camaros (14" I think). I thought it would feel a bit "boney" since it is so thin compared to my DDs, but it is really comfortable to hold and drive with.
Oh yeah, remember the mountsare way different than the later model wheels. (turn signal cancel cam/mount), so some wheels will mount, but the turn signals won't cancel correctly. I switched to 69 C10 column in mine, so it wasn't a big deal after the switch.
Old 07-15-2016, 10:15 AM   #3
LVPhotos
LVPhotos's Avatar
I put in a Moon Blue metallic Blue in with my Manual Flaming River rack quick ratio. 3/4 to one side and 1-1/2 lock to lock.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-17-2016, 01:40 AM   #4
64shortbox
64shortbox's Avatar
My same truck. First pic. Olds 442 steering wheel with a turned aluminum horn center. Second pic. close up of my horn center, third pic billet flamed wheel & horn cap with (fake) wood grain trim. Quite a bit of time passed between the first 2 pics & that last one. I can see in the last pic I had added my 64 Chrysler A/C vents, 73 Power Disc Brake pedal mod and a suspended gas pedal and since that last pic I've had the seat reupholstered & added power windows. Are these trucks ever done? Next on the agenda - a Cadillac parking brake so when I drop the truck into Drive or Reverse the brake will release automatically. Yep, I'm one lazy SOB.
64shortbox is offline   Reply With Quote
Old 07-17-2016, 10:04 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
I also like the original steering wheel look and struggled with a smaller diameter steering wheel after going with power steering. I had an old deluxe steering wheel that was worse for wear, but the hub was salvageable. I used an old Pontiac steering wheel that I had reduced the diameter of many years ago for a car that I sold long ago.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-17-2016, 12:29 PM   #6
62stepside longbox
62stepside longbox's Avatar
^^ that smaller deluxe wheel is the cats meow
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-17-2016, 02:39 PM   #7
cheavy metal
cheavy metal's Avatar
that smaller wheel is beautiful. well done
66 red and white gmc 350ci 700r trans now a project truck will be my daily driver rat rod
66 burgundy and white gmc 283ci th350 trans gotta ton of good parts current project
old school rulez, West Coast Canadian style
cheavy metal is offline   Reply With Quote
Old 07-21-2016, 11:55 AM   #8
scoot_mcgrute
I forgot I made this thread, too much time spent in the garage I guess
Thanks for the pictures and that smaller deluxe wheel is awesome!
1966 Army Truck
Old 07-21-2016, 12:14 PM   #9
Wingnut Way
Wingnut Way is offline   Reply With Quote
Old 07-23-2016, 01:54 AM   #10
Kenfuzed
Kenfuzed's Avatar
I too am looking for a smaller diameter wheel. Mine is the deluxe wheel found in pre-64 models and just a bit oversized for my taste.
Keep the images and ideas coming, I need one that gives me some leg room without doing a column swap.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 07-23-2016, 06:37 AM   #11
Wingnut Way
Forgive me if I'm wrong here and if I got time I'll try and look up the information but I could swore you could get a smaller diameter one as a re pop. 59 Biscayne wheel same thing. It's been a while since I did the swap on mine but I remember I was adamant on having the oem larger wheel which they don't make anymore from my knowledge so I forked out some cash.
Old 07-23-2016, 08:13 AM   #12
Wingnut Way
Same as 59 belair* sorry and i guess I'm full of false hope all I see is the smaller impala reproduction
Old 07-23-2016, 10:30 AM   #13
LVPhotos
LVPhotos's Avatar
Eckler's Classic Chevy has 15 in versions of stock
http://www.classicchevy.com/catalogs...wheel+&x=0&y=0
