Old 07-15-2016, 04:12 PM   #1
sxh9057
Heater\Air duct box help
I bought the AC parts (in boxes) from a guy to put in my non-ac cab 72 c10. When I go to connect the outer Heater box that mounts under the dash to the Air Duct selector box, it does not match up very well. Is there some kind of narrow spacer that goes between the two that I am missing or should the two just bolt together?
sxh9057 is offline   Reply With Quote
Old 07-15-2016, 04:26 PM   #2
100%Chevy
Re: Heater\Air duct box help
Go here-
http://www.lmctruck.com/chevrolet/
They have a breakdown on how all the parts go together once you find the correct area.Look at heater parts.
Mike.
100%Chevy is offline   Reply With Quote
Old 07-15-2016, 04:36 PM   #3
sxh9057
Thanks for the quick response & information. I live in KC area and know LMC all to well I have that but it does not show a good representation of that. Going to see if I can find someone that has one I can look at. Thanks again
Old 07-15-2016, 06:21 PM   #4
Grumpy old man
Grumpy old man's Avatar
Post pictures when asking questions it makes it ten times faster to get good information ☺
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-15-2016, 06:28 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Heater\Air duct box help
See if this helps. This is both parts outside and inside no other parts needed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-15-2016, 07:02 PM   #6
sxh9057
Andy436, I have that same PDF document. If you look at “HEATER AND AIR CONDITIONING 1A-32”. “Fig. 39—Heater and Ducts” it has another breakout and appears to show a thin square piece that goes between the “heater core and distributor assembly” and the Air Duct selector box (which in the picture diagram you provided is labeled as “to right of dash outlet”, “To left of dash outlet” and “to center dash outlet” It with where the two items join together.
If I align the holes together for them to “bolt up” then the opening does not match up exactly.
Grumpy Old Man- I tried to provide some pic’s but get this error message every time I try to upload pictures:Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
I have sent several requests to the administrator with no response and same result every time I try to upload pictures. I understand a picture is worth a 1,000 words but no luck with uploading.
I appreciate all the help and assistance. Not sure if something goes between them like it appears in the 72 PDF document called HEATER AND AIR CONDITIONING 1A-32”. “Fig. 39—Heater and Ducts” or not.
Old 07-15-2016, 08:56 PM   #7
Andy4639
Old member
Andy4639's Avatar
My 71 has no such piece. The one slides into the other one and only has screws in one side if I remember correctly.
Old 07-16-2016, 01:04 AM   #8
Gromit
Doesn't the Non A/C Cab have a very different set of holes (in size, shape and positioning) in the firewall? I'm sure it was that way in 1970 but I don't know the later years.. I think you need a template and will need to cut some areas and maybe plug others. Maybe best to get an actual A/C firewall but I'd be surprised if anyone went that far..
Gromit is offline   Reply With Quote
Old 07-16-2016, 02:11 AM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Literally, you're attaching the air duct to the heater box:
Duct Air Selector - Box 3:
Mounting the Duct Air Selector Mount the unit to the Heater Box using two 5/16" head tapered screws. The annex portion of the unit inserts into the metal bracket fixed on the Heater Box.
Cable Routing The cable for Box 3 was seated below the cable for Box 1. Not much else to this when mounted.
Mounting the Cable See Box 1 for attaching the wire to the lever. Only difference is when the unit is in a mounting position, the cable should be positioned below the plate on the unit for mounting the cable bracket (i.e., the wire wraps clockwise).
A/C Compressor Clutch Switch (button): The switch mounts to Box 3 using two 5/16" head tapered screws. This triggers the A/C when the lever pushes the switch button, where the A/C heater control is set to COLD.
Tee Adaptor. The adaptor fits on top of Box 3. The duct tube faces the LH (TS).
Nothing else to it on my 71. By chance your heater box isn't right?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-11-2019, 12:07 PM   #10
Hotcorner
Hotcorner's Avatar
Reviving a fairly old thread, I have a couple questions. First of all, my truck is clearly a factory air-conditioned truck, but I have no center vent outlet for the air-conditioning in the middle of the dash. I do, however have the two side vents. What gives? Is that normal?
Secondly, does the duct flow selector box amount to anything other than the heater box? Seems like everything is just floating under my dash.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 03-11-2019, 02:16 PM   #11
Jim Boy
Smile Re: Heater\Air duct box help
Gromit is right. When I converted my 68 to A/C I had to block portions of the fire wall and I believe cut other portions. I also think I had to drill some mounting holes through the fire wall as well. Nothing was between the two pieces except the fire wall. I have pictures but Can't upload. Good luck and have a good day.
Jim Boy is offline   Reply With Quote
Old 03-11-2019, 02:26 PM   #12
B. W.
B. W.'s Avatar
Your truck should have the center vent with factory A/C. dash may have been replaced or cab was replaced or fake spid.
If you remove the inner / outer boxes you can tell if the A/C was added. Different holes than heater only. You can also look on the inside the dash for repair welds.
The inner box is supported in the center with a screw though the fire wall just above the center heater outlet. Have some pics at work, will post later.
B. W. is offline   Reply With Quote
Old 03-11-2019, 02:31 PM   #13
Hotcorner
Hotcorner's Avatar
Just replaced heater core. It’s definitely factory AC, based on the firewall.
1969 GMC K25
Old 03-11-2019, 02:33 PM   #14
Hotcorner
Hotcorner's Avatar
That would be great!
1969 GMC K25
Old 03-11-2019, 03:15 PM   #15
B. W.
B. W.'s Avatar
Here's a pic: (I have a 1/4" bolt stuck in the hole just to mock it up)
Old 03-11-2019, 03:48 PM   #16
Hotcorner
Hotcorner's Avatar
Thanks!
1969 GMC K25
Old 03-12-2019, 11:38 AM   #17
Longhorn 69
Junior Member
Hear are pictures of the differences of a 69 non ac cab firewall, Red, and a 72 Ocre a/c cab firewall.
Greg
69 Longhorn 396, 4 Speed SM 465, PS, PB, No Air
Longhorn 69 is offline   Reply With Quote
