Old 07-15-2016, 06:55 PM   #1
jaws61
mustang two tie rod ends or extended rack??
Hey
I"m curious on what is better to do for a mustang two front end..
Run the longer fairmount tie rod ends (longer than stock ones) or extend the rack with the kit to make it work??
Thanks!!
jaws61 is offline   Reply With Quote
Old 07-15-2016, 07:17 PM   #2
mr48chev
mr48chev's Avatar
Re: mustang two tie rod ends or extended rack??
How was the track widened? By using a wider crossmember or by using longer A arms?
Wider crossmember I'd probably go with a longer or extended rack but if it has longer A arms I'd go with the longer tie rod ends. Match the stretch if you will.
My ongoing truck projects:
Old 07-15-2016, 08:47 PM   #3
jaws61
The track is the normal 60-61 inches but for a mustang two suspension, With the normal tie rod ends it wouldn't reach.
There for there is two option
extend the rack with heidits kit or use the longer tie rods from fairmount..
Old 07-16-2016, 11:02 AM   #4
_Ogre
_Ogre's Avatar
the thunderchicken rack for my fatman mustII came with a 4.25'' extender
shop air compressor timer
Old 07-16-2016, 11:16 AM   #5
mr48chev
mr48chev's Avatar
If the pivot point of the A arms is the same distance as stock but you need to reach the spindles you have because they are different I'd go with the longer rod ends. The TF guys need a wider crossmember to work with their frames and that is why they need the extended rack.
Old 07-16-2016, 12:41 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
This is how you figure out the rack length to eliminate bump steer.
Ford has a multitude of racks and rod ends to interchange with and get very close to perfect. Get an old Moog book it will have all the measurements in it.
dwcsr is offline   Reply With Quote
Old 07-16-2016, 01:00 PM   #7
mr48chev
mr48chev's Avatar
Thanks, I saved that. It also works for a tie rod/center link off the steering box setup.
Old 07-17-2016, 08:57 PM   #8
jaws61
Thanks dwcsr
That made life bunch more simple!!
