Old 07-15-2016, 08:01 PM   #1
Jraney
New front end on my 64
Hey folks I've got some questions. I have my spindles. They are listed as fitting trucks from 73-87. Now the front end parts. Ball joints, tie rods, rotors, etc. what year is the best to get for my set up. The truck is a 64 Chevy c10. Going with disc brakes on the fron only. Also any recommendations on the brake lines I need. All I find in my magazines just say manual brakes for my truck year. Any help would be greatly appreciated. Thanks
Jraney is offline   Reply With Quote
Old 07-15-2016, 11:53 PM   #2
Captainfab
60-66 Nut
Re: New front end on my 64
Since you have '73-'87 spindles, you need the rest of the components for the same year range. I always recommend upgrading the entire steering linkage also. That way all of the steering and braking components are of the same year range or specific year. To upgrade the idler arm, you will have to position it correctly on the frame and drill the holes. You will want to keep the draglink parallel to both the bottom of the frame and the suspension crossmember.
Old 07-15-2016, 11:56 PM   #3
Jraney
Ok. Thanks for the info.
Old 07-22-2016, 06:12 PM   #4
Jraney
So what the ball joints. I have my original control arms. So do I order my year or the spindle year for the ball joints.
Old 07-22-2016, 11:45 PM   #5
Captainfab
60-66 Nut
That includes ball joints
Old 07-22-2016, 11:47 PM   #6
Jraney
Control arms are fine tho right?
Old 07-22-2016, 11:55 PM   #7
Captainfab
60-66 Nut
Yes. The '73-'87 ball joints will fit your original control arms just like the original ball joints did.
Old 07-22-2016, 11:56 PM   #8
Jraney
Ok. I'll be so glad when I get this done. Thanks for the advice.
