Old 07-15-2016, 08:49 PM   #1
GR8-68
GR8-68's Avatar
Get a grip !!
Don't throw that old cracked wheel away, fix it and get a new grip on having the original. I have seen so many being ditched over the years, it is time to save what original parts are left. As long as the hub is not too bad that wheel you have may just be able to be saved. The following pics are the wheel from my 70 I decided to use as a practice wheel as the hub was shot on it. To the point of getting what I did in primer I had invested about 3 hours into it.
Before starting the project
Using the dremel to clean up the cracks and remove any faulty material
Using a 2 part epoxy to fill the cracks in
Once it hardens I begin sanding and shaping it back
Then I lay three to four coats of primer sealer to it and it is ready to paint the color of your choice
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-15-2016, 09:24 PM   #2
saxart
saxart's Avatar
Re: Get a grip !!
Larry-
Great thread! I'll ask the million dollar question...
I've restored tractor steering wheels using JB weld, but they always seem to crack again. Do you mind mentioning what brand epoxy you're using on these? It looks like more of a "clay" type consistency rather than a liquid or semi-liquid.
saxart is offline   Reply With Quote
Old 07-15-2016, 09:36 PM   #3
GR8-68
GR8-68's Avatar
Re: Get a grip !!
It is POR 15 2 part epoxy, it goes on like play dough but hardens like steel. You can sand it shape it drill it and paint it
Larry
"Project 68"
paypal.me/ldgrant
Old 07-15-2016, 09:38 PM   #4
GR8-68
GR8-68's Avatar
Re: Get a grip !!
It takes a bit of time and a lot of patience to get it where I am happy with it but beats seeing a useable wheel go to the scrapper or landfill
Larry
"Project 68"
paypal.me/ldgrant
Old 07-15-2016, 09:43 PM   #5
GR8-68
GR8-68's Avatar
Re: Get a grip !!
I have several wheels I have that will soon be up for sale also may have a couple at the Carlisle show if anyone wants to check them out. I have four 67-68 wheels right now, a 60-63 gmc wheel and a 69-72 wheel I just bought all of which will be restored and put into primer ready for the color of the new owners choice
Larry
"Project 68"
paypal.me/ldgrant
Old 07-15-2016, 11:27 PM   #6
saxart
saxart's Avatar
Re: Get a grip !!
Awesome, thanks for the info!
Old 07-15-2016, 11:33 PM   #7
Leonard60
Re: Get a grip !!
Do you think if you were to spray that rubberized paint on the wheel instead of just spray paint it would hold up and maybe give it a little softness?
Leonard60 is offline   Reply With Quote
Old 07-15-2016, 11:39 PM   #8
71swb4x4
71swb4x4's Avatar
Re: Get a grip !!
That looks great!
Wow, those are some massive cracks in the middle. Are you filling those the same way?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-15-2016, 11:53 PM   #9
Blue/72
Blue/72's Avatar
Re: Get a grip !!
How do you recreate the grain?
My dad always says that HEI distributers are pointless...
•1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money..
•1967 c10 with tach, dropped 3/5 on deep dish rally's
•1972 Cheyenne Super. Sold
Blue/72 is offline   Reply With Quote
Old 07-16-2016, 12:01 AM   #10
toolboxchev
Re: Get a grip !!
Love to see it finished, please post a pic of your work!
toolboxchev is offline   Reply With Quote
Old 07-16-2016, 01:10 AM   #11
Gromit
Re: Get a grip !!
Has anyone tried one of those sewn-on leather steering wheel covers? I understand that you soak the leather in water and sew it on wet with something like a baseball stitch (two needles) and when it dries it pulls all the slack out and is tight as a drum head..
I think that would work well once you repair the big cracks as it keeps the UV radiation off that plastic..
Gromit is offline   Reply With Quote
Old 07-16-2016, 04:22 AM   #12
GR8-68
GR8-68's Avatar
Re: Get a grip !!
Originally Posted by 71swb4x4 View Post
That looks great!
As I stated this was just a practice wheel and I have not tried anything with a damaged hub to this extreme. I have a few things in mind but have to still test it to see if it will hold up.
This one is split apart so far the retaining ring fell out of it
I will update everyone when I see if it is possible to repair one to this extreme
Larry
"Project 68"
paypal.me/ldgrant
Old 07-16-2016, 04:25 AM   #13
GR8-68
GR8-68's Avatar
Re: Get a grip !!
Another hurdle I need to jump
this one was cracked into the woodgrain a little bit on the outer side so I planned to use a dremel with a fine point cutter to reproduce the woodgrain.
Luckily it is only a little bit of it in the center.
Larry
"Project 68"
paypal.me/ldgrant
Old 07-16-2016, 09:24 AM   #14
Redline novdog
Redline novdog's Avatar
Re: Get a grip !!
Nice ! I need to do mine also. Thanks for the por-15 epoxy idea. I have used it before, but not on a steering wheel. Its' good stuff. I am curious as to how well paint will hold up to the use. Any ideas on the kind of paint??? Possibly interior vinyl trim paint?
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 07-16-2016, 09:28 AM   #15
Grumpy old man
Grumpy old man's Avatar
Re: Get a grip !!
Interior vinyl trim paint won't last very long even when using Bulldog adhesion promoter .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-16-2016, 09:49 AM   #16
Re: Get a grip !!
Urethane.
