Old 07-16-2016, 09:53 AM   #1
cam.man67
cam.man67's Avatar
Headlights on whenever truck is running?
Bit of a head scratcher here. Other morning, the GMC wouldn't turn over...turns out the positive terminal was loose on the batter. Once I tightened that up, it started up fine and has been fine ever since. However, since that time, whenever the key is on, the headlights turn on. They don't shut off unless I turn the truck off. Any idea what may cause that?
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 07-16-2016, 11:08 AM   #2
Cape Codder
Cape Codder's Avatar
Re: Headlights on whenever truck is running?
DRL Daytime running lights. Do you have a green headlamp indicator lit on the dash panel? I pulled the fuse on my 98 so they don't come on but I still get the indicator lamp. I found it annoying that I couldn't flash my headlamps to let people go without turning the lights on then using the high beam switch.
Cape Codder is offline   Reply With Quote
Old 07-17-2016, 09:12 AM   #3
speedygonzales
speedygonzales's Avatar
The only GMC listed in your "inventory" the 96 was in fact DRL. If you push the emergency brake, the lights will go off. Another indication it has DRL.
Little confused by the way you worded the thread. Are you saying prior to the other day, the lights were not on when it was running. Now that you tightened the battery cable the lights are on? Or did you not notice them on until after you tightened the cable?
You can disable it but why? Wasn't it invented to help with safety?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 07-17-2016, 10:19 AM   #4
1badgmc
1badgmc's Avatar
These trucks first got Daytime Running Lamps (DRLs) for the 1996 model year. The DRLs run your lowbeam headlights at reduced power. No other running lights (parking lights, taillights, etc.) are on while the DRLs are on. I've owned two of these trucks with DRLs and in each one I pulled the fuse (Fuse #15 "DRL/FOG") before driving the truck off the lot. When you do pull the fuse, you still have the green DRL indicator light on the dash. You can also push your parking brake pedal one click to turn them off without engaging the brake, but then you have the parking brake indicator light. The DRL module us located under the steering column. Removing/unplugging that will disable them as well.
Old 07-17-2016, 06:00 PM   #5
cam.man67
cam.man67's Avatar
I don't think DRLs are what I'm dealing with here. This never happened before the battery thing. There's no green light on the dash. I mean, yes, it appears to be DRLs, but they've never been on before.
Old 07-17-2016, 07:09 PM   #6
speedygonzales
Do they go out when you push the e brake?
Pride and joy
