Old 07-16-2016, 02:08 PM   #1
Joesjunk
Joesjunk's Avatar
Help, '87 454 runs too hot
Looking for some advice on why my bone stock, 101k mile 1987 V/30 truck wants to run hot. I have been over everything, even had head gaskets changed ( although it didn't appear to need them). It seems to stay cool just sitting running, even with the ac on. But gets warmer on the road. It never over heats, but gets hotter than it should. It has a 180 thermostat, and the gauge is working correctly. It will sometimes get up to the next mark on the gauge. Any indepth advice?
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-16-2016, 02:38 PM   #2
Matt Man
Matt Man's Avatar
Re: Help, '87 454 runs too hot
How is the fan clutch, it has one I'm assuming? Mine did the same thing, replaced the fan with a 6 blade instead of 3 and a heavy duty fan clutch for the so cal desert climate.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 07-16-2016, 02:43 PM   #3
gmachinz
If your temp sender is in the head, I'd say it's normal. The head will read 15-20 degrees warmer than the intake which is the usual spot. Not to mention the gauge could be off as much as 3-4 degrees too.
gmachinz is offline   Reply With Quote
Old 07-16-2016, 03:35 PM   #4
71swb4x4
71swb4x4's Avatar
I agree, I don't think it's too hot.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-16-2016, 03:41 PM   #5
gmachinz
If it IS bone stock, it couldn't hurt to replace the water pump....otherwise, just for giggles can you swap th sender to an intake passage to see what the difference is on the gauge? If it's a noticeable difference, I wouldn't worry about it running too warm.
Old 07-16-2016, 04:37 PM   #6
tucsonjwt
Did you use an infrared thermometer on the engine? This would be a way to check on the accuracy of the gauge. I had an over temp condition on my 02 Cavalier when driving at highway speed and it was a clogged radiator. When I replaced the radiator all was well. Replacement radiator was just an Autozone plastic/aluminum one.
My 83 C20 454 never gets much above 180, but it has a factory oil cooler and an auxiliary fan in front of the stock radiator. Of course, it is a Qjet, not TBI like yours. I did replace the fan clutch and water pump with AC Delco ones several years back. My engine is stock with all smog equipment intact.
tucsonjwt is offline   Reply With Quote
Old 07-16-2016, 04:47 PM   #7
AntiGov
AntiGov's Avatar
Does yours have the odd looking factory auxiliary fan ? My 88 454 crew does. There were two for sale in the parts forum recently. I know you want to keep it all stock and these are factory.
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 07-16-2016, 06:21 PM   #8
Joesjunk
Joesjunk's Avatar
I have tried most of what you guys are saying. It has a new GM clutch on the fan. It is 100% bone stock except for dual exhaust and no converter. I even put a mechanical gauge in the other head and it reads the same as the factory gauge. I have the factory oil cooler and the aux fan in front of the radiator. I have a new GM radiator I am going to swap in it tomorrow and see what happens.
I also have an identical truck, only an '86 with a carb and it never runs above 190
Thanks for the replays. I'll let you know how the different radiator works
Old 07-17-2016, 09:35 AM   #9
tucsonjwt
I think a power flush would be a good idea when you install the new radiator. I think that radiator will do the trick. Good luck.
Old 07-17-2016, 09:49 AM   #10
gmachinz
Wow....I'm not surprised you have a NEW GM radiator in your collection of parts-but man those are rare to find!! You can't get an actual BB spec radiator at parts stores anymore-they all try to sell a 3-core. NOS Harrison BB radiators gotta be tuff to find!!
Old 07-17-2016, 10:59 AM   #11
Dead Parrot
Before you worry too much, verify the temp with an outside source. IIRC, the temp rating on a thermostat is the start to open temp. So your 180 is just starting to open at 180. It will take to 190~195 for it to be fully open. Now if your gauge is just 5% off, you could have a reading of 205 by the time your thermostat is fully open. If your gauge is 10% off, the reading could be 210~215. This assumes the sender is perfect. If sender is also 5 or 10% off and especially if it is off in the same direction as the gauge, your reading could well be 210~220 even if the actual engine temp is proper for your thermostat.
Also, double check the cluster contacts for corrosion and clean up the cluster grounds. Assuming it is original, your electrical stuff is 29 years old and it doesn't always age well.
Might try an aftermarket temp gauge and sender and see if it responds the same.
Dead Parrot is offline   Reply With Quote
Old 07-17-2016, 11:49 AM   #12
S10Fan
Old Heap Driver
Infrared thermometer is a good investment for car guys. I fought a heating issue with a V-8 S-10, later found the gauge was way off. I had been using Sun gauges, called Sun and a tech guy told me their gauges had a 20% tolerance. Yeah, 20%!!
I realize yours is a factory gauge, just make sure it really is hot before fixing a motor that isn't broken.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-17-2016, 01:48 PM   #13
Joesjunk
Joesjunk's Avatar
I have used the infrared thermometer on it and put a mechanical gauge on it. It is running hot. I swapped the radiator just now and just waiting on a new upper radiator hose to come in from the auto parts store in a few hours. Ill test it out this afternoon and give an update
Thanks again for the replies
Old 07-17-2016, 05:57 PM   #14
Joesjunk
Joesjunk's Avatar
Well I swapped the radiator out of my '86 K/30 into the '87 and so far that seemed to have fixed my problem. So now my NOS radiator will go in my '86 K/30.
I even had a radiator shop look at my old radiator over a year ago and they thought it looked ok. Guess not lol
Old 07-17-2016, 09:23 PM   #15
HOTFUN
HOTFUN's Avatar
I would have bet the fan clutch first as I have seen that more often than any other cooling at speed issue but one more check is the radiator cap. It has to be 15 lbs to pressurize the crossflow design radiator and if the spring is weak or gasket tore it will not circulate the coolant properly. Just a thought if the radiator shop said the radiator had pressure checked fine before.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 07-17-2016, 09:45 PM   #16
Joesjunk
Joesjunk's Avatar
Mark, they just looked at it, didn't do a test on it. It has a new GM cap on it too.
Old 07-23-2016, 05:15 PM   #17
SparkyRnD
SparkyRnD's Avatar
We also make radiators here in the USA using domestically sourced materials by hand to fit your truck (and we can put the inlet / outlet wherever you need at no additional charge). They are all tig welded, no epoxy or glue either. Plus, we are a site sponsor. Let me know if you are interested.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 07-23-2016, 08:13 PM   #18
Joesjunk
Joesjunk's Avatar
Thanks for the info. I did get the truck fixed and running just like it should.
Old 07-23-2016, 09:00 PM   #19
SparkyRnD
SparkyRnD's Avatar
Cool! (pun intended)
