Old 07-16-2016, 07:33 PM   #1
rmiles
high rpm carb problem 1953 3100 original
I just replaced the fuel pump and changed out the fuel filter from a filter and regulator to a glass bowel filter. All starts well, idals fine, seems to be ok at mid range ,but when I give it the fuel throttle it hesitates and runs very rough.
The fuel pump should not be the problem, would the switch from a fuel filter with a regulator (2LBS listed) effect the high end or am I looking at a carburetor problem. I did not have this problem prior to replacing these two parts? Help please?
rmiles is offline   Reply With Quote
Old 07-17-2016, 07:26 PM   #2
tmoble
Re: high rpm carb problem 1953 3100 original
is this on the road or in the driveway in neutral?
tmoble is offline   Reply With Quote
Old 07-17-2016, 09:47 PM   #3
rmiles
It is in the drive away haven't road tested yet
