Old 07-16-2016, 09:45 PM   #1
Mrturner1
Little bit of grey smoke during idle....
So I've been working out of town and I got back yesterday and wanted to take a drive in the old C10 see'ins how I finally got it dialed in. I'm letting it warm up and my wife comes out and says it's burning her eyes in the house, and I can see the air is a little hazy around the back of the truck. I drove it today and pulled over to check it out, and at an idle I can barely see the smoke coming from the tail pipes, but what was weird is it was sunny outside and I could see the shadow of it on the ground right after the tailpipes by the rear tire. Weird. Not sure what that means, but I'm really hoping my bottom end its going out especially because I finally got the truck dialed (mostly) so I can drive it now and not worry about reliability.
Motor is 10.3-1 355cid, RHS 170 heads, Comp 280H, 1.5 roller tips, Edelbrock performer rpm manifold, 1" phenolic spacer under a Holley 750dp that has 71's in front and 77's out back, 6.5 power valve and stock pump cam and pump cam position. I'm certainly no expert on jetting, and my hunch tells me that 71/77 is too much, it came with 75/76 jets. Timing is 32* total, with 18 initial and all in at 3000 rpms. TH400 with 3000rpm stall, 3.73 mini spool rear
Mrturner1 is offline   Reply With Quote
Old 07-16-2016, 11:11 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Little bit of grey smoke during idle....
It's the hot fuel you've been dumping in the tank , run it out and use premium unleaded .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-16-2016, 11:21 PM   #3
Mrturner1
Can you explain just so I understand what you mean? That stuff can make grey smoke? It started right after I fattened up the a/f mixture screws on the carb too. I turned those in a half turn and that off idle stumble went away, I may have over done it though I suppose. I hope you're right, I was so bummed havin just got the thing running good finally
Old 07-16-2016, 11:34 PM   #4
Grumpy old man
hot fuel is famous for burning eyes
Old 07-16-2016, 11:40 PM   #5
Mrturner1
Well ya I get that part, but could it be causing the smoke I'm getting while its idling?
Old 07-17-2016, 12:07 AM   #6
Grumpy old man
Stop looking for things to fix and just drive the dang thing . move on to brakes and suspension and lock the hood down .its running good LEAVE IT ALONE !
Old 07-17-2016, 02:15 PM   #7
Mrturner1
Always bustin my butt.
I don't want to work on the engine anymore, I'm just getting a feeling that it's burning a ton of oil now (rings or bearings or something) and my time with it running good finally is going to be really short lived.
Old 07-17-2016, 02:22 PM   #8
Grumpy old man
Hey it's all in fun we've been a long way with you and this engine ,I want to see it last a long time so you can have some fun with it . Are you sure your girl hasn't been twisting it wide open thru the canyons while you were gone ?
Old 07-17-2016, 02:38 PM   #9
davepl
davepl's Avatar
Running lean can make it burn the eyes. But so can rich. Without a exhaust gas analyzer you're unlikely to diagnose why your wife doesn't like it.
I think the correct answer is "Because it's old and doesn't have catalytic converters so I'm going to go drive the damn thing so it's not sitting at home making bad smells and causing me to want to take it apart again!"
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-17-2016, 02:57 PM   #10
Mrturner1
It definetly smokes it's not just her saying that lol it's never smoked before, and smoke usually means something bad is going on, especially if it just started for the first time since I got it. Do you guys drive yours around if they start to smoke or do you typically figure out what it is? I'm not so much worried about the burning eyes, it's got a gallon of 110 and probably way too big a jet in the primary, I can deal with that. But it goes from never even a puff of smoke to making the front yard hazy and a visible smoke at idle is a little concerning.
Old 07-17-2016, 02:58 PM   #11
Mrturner1
Heck no ever since I put the stall converter in she hates it lol that's why she wants a 73 K5 because she can't drive mine anymore haha
Old 07-17-2016, 03:26 PM   #12
Grumpy old man
post a picture
Old 07-18-2016, 12:17 AM   #13
Mrturner1
Ok so I went to take a video and I'll post that up shortly, but I noticed something while J was down there, the smoke is DEFINETLY black.
Old 07-18-2016, 04:36 AM   #14
Grumpy old man
If it's black it's running rich a mixture fouling issue , too much fuel .
