07-17-2016, 12:56 AM | #1 |
Front differential vacuum tube
Where does the front differential vacuum tube lead to and attach to?
Mine just ends near the engine into mid air. That can not be good. Please help....Thanks! 1972 Blazer |
07-17-2016, 01:30 AM | #2 |
Re: Front differential vacuum tube
It's a vent tube, not a vacuum. It just provides atmospheric vent so pressure doesn't build up and cause a leak.
07-17-2016, 05:29 AM | #3 |
Install a vent cap on the hose end. The hose should be clamped to top of the frame
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
07-17-2016, 03:27 PM | #4 |
Rh frame rail where the upward bend is in the upper surface.
I think may be shared with same hole as battery cable from above?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
07-18-2016, 09:09 PM | #5 |
K5drive
Anyone know where to buy the vent cap ?
07-18-2016, 09:32 PM | #6 |
Not sure if the vent line is 5/16" or 3/8". Here is a 3/8" from Inline tube.
http://www.ebay.com/itm/1964-81-GM-a...dW5ERc&vxp=mtr Last edited by bluek5; 07-18-2016 at 09:35 PM. Reason: Picture |
07-18-2016, 10:25 PM | #7 |
The donor 2003 4X4 GMC Sierra I got my engine from used the same vent plugs, so you can grab one from the wreckers.
07-21-2016, 12:17 AM | #8 |
Mine were 5/16. I bought some dorman part that look identical. I'd imagine that you could get them at any jobber supply place like Napa, etc.
07-22-2016, 12:04 AM | #9 |
Carpe manana
These are still available through GM also...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
