Old 07-17-2016, 01:10 PM   #1
78 k20 8,400 gvrw
78 k20 camper special 8,400 gvw 77k original miles.
New member here, found this forum while working on my NP203 transfer case on my project truck and really liked it so I thought I'd setup a profile and a project thread.
I will add pics of my truck later today.
So I've had it since February and just now got it back on the road. I bought it for $400 with brand new 16.5 tires on it. I was amazed how clean it was when I got it and the previous owners had managed to keep all of the original parts, even the original hubcaps
The previous owner told me they just sunk $3000 into rebuilding the transmission (turbo 400) and transfer case (original fulltime NP203) it also had a brand new exaust system.
So far I've had to replace the flex plate and starter, headgaskets, carburater, exaust manifolds, water pump, all the fuel lines, hoses, belts, front knuckle joints, installed mile marker 502 conversion kit, made custom twin stick shifter, front brakes, flushed brake fluid, installed twin eletric fans, installed 10,000 gvw trans cooler, put in trans temp gauge, fixed misc. Wiring problems, replaced chrome valve covers for stock valve covers.
I've got pictures of most all of this and will post them up soon.
Next big projects will be rust repair, and beefing up my NP203 with a 73-74 one piece tail shaft housing and the actual replacement shaft if I can find one.
78 k20 8,400 gvrw is offline   Reply With Quote
Old 07-17-2016, 04:33 PM   #2
78 k20 8,400 gvrw
Re: 78 k20 camper special 8,400 gvw 77k original miles.
First getting it in febuary
Running before NP 203 conversion.
Old 07-17-2016, 04:42 PM   #3
78 k20 8,400 gvrw
Np 203 conversion
Old 07-17-2016, 04:52 PM   #4
78 k20 8,400 gvrw
Going through the motor.
Old 07-17-2016, 11:36 PM   #5
MTCK
MTCK's Avatar
Cool rig. I like the headache rack.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-18-2016, 05:20 PM   #6
78 k20 8,400 gvrw
Thanks, I got the headache rack in a trade right after I got the truck. I knew I had to do something before I started using it, it has the original sliding rear window and I know how hard those can be to find.
Old 07-18-2016, 05:27 PM   #7
78 k20 8,400 gvrw
Here are the options it came with. Just a few.
Old 07-21-2016, 06:40 PM   #8
86454k30
86454k30's Avatar
pretty cool truck.
86454k30 is offline   Reply With Quote
