![]() Join Date: Oct 2012
Rolled 65 chevy truck
Look what I found about 3 miles from my house. It needs a cab but has a nice frame and bed. Thinking about making it a hot rod with a 454.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: Rolled 65 chevy truck
Wow! For a minute there I thought that YOU rolled YOUR truck! Nice find. There seems to be plenty of good stuff there. What are your plans for the cab? Looks like finding another cab would be time and money well spent rather than attempting to repair that one.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Not sure what I am going to do with this cab but I think it is to bad to fix. I have another cab found I could get for a song. Any idea on an old school hot rod? I was thinking primer black with a huge motor
I may sound like an old fart but big engine = gas hog go fast but not very useful. Expensive to build the engine. Tears up transmissions too. Plus all that power needs a safe reliable suspension. That means more money.
How about just making it a cool looking ride with great styling? Black, red, yellow, any color will work. Just make sure you can stay in budget. What good will it be if you have a great big engine if you run out of money? Don't let me tear apart your vision or dream. It's your truck so build what makes you happy. Just make sure it's safe.
Well I have to finish this one first. It is my 3rd frame off restoration I wanted to do something different with the wrecked one
Ok. I see this isn't your first rodeo. Haha!
Go for whatever makes you happy.
Doesn't look like a roll over more like he hit a protruding object up high?? On second thought looks like it rolled on the drivers side and the roof buckled...
![]() Join Date: Apr 2015
Nice find. Just curious, what's your plans for the wrecked cab?
Wade |
Just cut the roof off, make some front pillars to hold a windshield and go roadster style!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Depending on the condition of the rest of the cab, that one wouldn't be that hard to fix. Just need another roof section from the bottom of the windows up. It looks like the rear of the cab is not damaged much.
Not sure on the plans for the cab. Might look into replacing the top. It is a big back window but would be easier to replace the cab. I think the back of the cab is bent also. It is touching the front of the bed section
If you decide it is not worth the effort and want get rid of it keep me in mind. I would like to find one for a different kind of project, just don't want to use one that is in good enough shape for a truck build. Thanks.
#13 |
I would strip it completely for parts for another cab would you want just the bare cab?
#14 |
#15 |
Well I got my blue 66 completed and drove it some and sold it last week It now lives in Texas. I am going to start working on this 65. Just going to make it a driver. Probably going with a cammed up 350 and leave the 3 speed on the column. I have a set of ralley rims found. Just need a cab ( a guy up the road has one I can get for a song) a hood a passenger door and a 350. Stay tuned
#16 |
If you come help me take it off I got one you can have! Also got a 455 / turbo 400 Buick hanging up in the shop!
#17 |
#18 |
Is that Kudzu in the engine compartment?
#19 |
Bought a 69 350 engine last night going to pick it up tomorrow. All I need now is a hood and passenger door and windshield, rockers and cab corners. I am going to trade a friend of mine for all the above for a 235 I have laying around. I have the rolled truck in the shop and my son is going to start the tear down tomorrow.
#20 | |
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
#21 |
Are you considering swapping out the roof and A pillars? I did one last year and had a build thread in the 67-72 forum called "Meet Homer".
One day had both roofs off and one tacked in place. Next day stich welded back up, & I had to swap entire back of cab also. Looks like that rolled cab is not too bad, especially with that big back window. I would want to save it if it was me. My .02Cents.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#22 |
I need to get a couple more pictures of the cab. It is really bad. I think the back glass area could be used on a big back glass conversion. The floor on the passenger side it buckled up and has come apart from the lower firewall. The back of the cab is bent out and touching the bed. The firewall on the passenger side has a bent in spot it is rough. I have a guy who is suppose to buy the cab and make something out of it but he has not got back with me.
#23 |
Also I have started a build thread on this truck on the project section.
#24 |
If it was rolled, I'd check the frame is straight also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#25 |
Checked it and it looks good
