Old 07-17-2016, 09:28 PM   #1
ggalv
Putting door handle on door correctly (1970 Chevy)
Right now my door handle is placed incorrectly. Basically, if the door handle is at a certain position the door keeps shut when I close the door, but when the door handle is at another position and I close the door it does not keep shut and will even open when I am driving.
I took the door panel off and trying to figure out how to put the door handle correctly. Appreciate your advice if there is some steps I need to follow when putting the door handle.
ggalv is offline   Reply With Quote
Old 07-17-2016, 09:48 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Putting door handle on door correctly (1970 Chevy)
I don't understand. There's just one position for the exterior handle. Can you describe these positions? Interior or exterior handle?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-17-2016, 10:07 PM   #3
ggalv
Its the interior handle.
Old 07-17-2016, 10:10 PM   #4
Grumpy old man
Grumpy old man's Avatar
interior door handle ,sounds like the latch actuator spring may be broken or the latch its self is worn out . look at the rivet on the door latch to see if it's loose if it is replace the latch
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-17-2016, 10:44 PM   #5
ggalv
There is a spring (clip) that goes around the handle to keep it in place, but that one is not broken. Also, once I put the handle in is position with the spring (clip) the handle does not turn do possible worn parts, it turns normally.
Old 07-18-2016, 12:15 AM   #6
71CHEVYSHORTBED402
The handle won't cause that anyway. Do what Grumps said. If that's right then it's the latch control. Only other possibility I can imagine is the rod between the control and latch, though I wouldn't think it would cause the problem. Give me a holler if you're stumped on assembly.
Tony
