Old 07-18-2016, 09:18 AM   #1
77c10
77c10's Avatar
6.0 oil pressure issue
I recently swapped a 2005 6.0/4L60E into my 77 c10. The engine had 225k plus miles on it when I got it. I never personally heard it run but was told by the guy that I bought it from that it held good oil pressure but had the normal LS lifter tick at idle. I tore into and below is a list of parts I replaced.
Main bearings
Rod bearings
Oil pump
Lifters
Timing chain
front and rear seals and gaskets
oil pan gasket
head gaskets
valley pan gasket
intake gasket
My issue is that my Autometer oil pressure gauge only reads around 10psi at start up. It goes up a little when you give it gas but not as much as I think it should. I tried a secondary mechanical gauge and get basically the same reading.
I have the sending unit in the location where the factory sending unit went.
I've pulled the plug on the left front of the engine and the one above the oil filter and both puked oil while cranking.
There isn't any knocking or rattling like I think there would be if it did actually have low oil pressure.
Does anyone have anything else to try?
Thanks in advance
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 07-18-2016, 10:11 AM   #2
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: 6.0 oil pressure issue
If you have an accurate mechanical gauge plumbed into the factory sender port and it reads 10 PSI that is what you have. Just for additional confirmation you could try another mechanical gauge to be absolutely sure- but the two gauges you have read the same. HTH
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-18-2016, 12:10 PM   #3
Willie Makeit
Willie Makeit's Avatar
sounds like you may need some cam bearings
Willie Makeit is offline   Reply With Quote
Old 07-18-2016, 01:16 PM   #4
77c10
77c10's Avatar
Do you think it's possible to replace the cam bearings with the engine still in the truck?
Old 07-18-2016, 02:21 PM   #5
akdg87
akdg87's Avatar
225k is quite a bit but there is the chance you used the wrong o-ring for the pickup tube, or possibly even pinched it while installing it.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 07-18-2016, 07:49 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
Nothing to do with the oil pressure but did you change the bolts when you replaced that stuff on your list...i noticed you didnt list them...LS bolts are torque to yield one time use bolts..
Old 07-19-2016, 08:31 AM   #7
chuckmc8
chuckmc8's Avatar
After thinking about this overnight, I tend to agree that is is very possible that the oil pickup to the pump seal is compromised. There are many many LS engines purring along with 225k on them
Old 07-19-2016, 03:29 PM   #8
77c10
77c10's Avatar
We had the pan back off of it Saturday and triple checked the pick up tube and o-ring. It doesn't appear to me that it is compromised at all.
Old 07-19-2016, 03:40 PM   #9
77c10
77c10's Avatar
I replaced the head bolts. Those were the only ones I knew that were torque to yield.
Old 07-19-2016, 04:04 PM   #10
Willie Makeit
the harmonic balancer/pulley bolt is another that is often overlooked
Old 07-19-2016, 04:51 PM   #11
77c10
77c10's Avatar
I stand corrected, I also replaced the balancer bolt as well. Totally forgot about that one! What a PITA to get the old one loose!
Old 07-19-2016, 04:53 PM   #12
77c10
77c10's Avatar
With hindsight being 20/20, I should've pulled the cam retainer plate while I had the front cover and timing chain off, pulled the cam and visually checked the bearings.
Old 07-19-2016, 10:50 PM   #13
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
The last oil pump I bought came with several pick up O rings. Make sure that you used the right one. They are very close in size and easy to confuse. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
