07-18-2016, 11:43 AM | #1 |
Rear crossmember help
Could someone please tell me what the length of the rearmost crossmember is? My truck is a 1970 short Stepside and the crossmember is missing. My left frame rail is bent and a friend of mine has borrowed a porta-power to help me get it straight. I want to get a new crossmember to install but wanted to make sure I got the frame distance right while I have to tool...
Thanks for the help. Anthony |
07-19-2016, 04:17 PM | #2 |
Re: Rear crossmember help
Which one of the cross members are you referring to? My '67 has 3 including the main one over the differential.
07-19-2016, 04:57 PM | #3 |
here
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
07-20-2016, 11:18 AM | #4 |
Thanks for the print.
07-20-2016, 11:24 AM | #5 |
The one thing that I don't see on that drawing is how to place the axle center lines on the frame. Rob@NoLimit gave me a measurement of 34 1/2" from the end of the frame on the rear to the rear center line and it seems to fall exactly where the drawing shows it.
07-21-2016, 12:56 PM | #6 |
all of the information you should need is there, it will just take some addition and/or subtraction from some some of the other dimensions.
do you have a Long wheel base or a Short wheel base? are there exsisting bump stops on the truck? what is wrong with your existing frame that it is not already located? we need info!!!!!
