Old 07-18-2016, 01:11 PM   #1
BBauer
Cool Front end and rear end swap
I have a 69 c10 swb that I am looking to swap to a 5 lug and disk brake set up. I amean also looking to swap the rear end, they are both coil spring. I have a donor 71 that I am going to be using for parts, what all do I need from the donor to complete the swap. Any tips or advice is greatly appreciated. I'm sorry if this has been covered before but I am new to this and this is my first build. Thank you in advance for the input.
BBauer is offline   Reply With Quote
Old 07-18-2016, 03:27 PM   #2
bbcmudtruck
Re: Front end and rear end swap
1. Unbolt undesired parts from vehicle.
2. Unbolt desired parts from donor vehicle.
3. Bolt desired parts onto vehicle.
4. Smoky burn outs.
bbcmudtruck is offline   Reply With Quote
Old 07-18-2016, 08:53 PM   #3
BBauer
Are all of the steering components and control arms direct replacement and interchangeable with each other?
Old 07-18-2016, 11:23 PM   #4
Ozzy2013
Ozzy2013's Avatar
Yup its all interchangeable as in change the complete rear and id swap the complete front end with the front cross member (engine cradle ) .Makes it very easy
Ozzy2013 is offline   Reply With Quote
Old 07-19-2016, 08:01 AM   #5
BBauer
What are the opinions of the steel A-arm bushings vs the later model rubber bushings?
