07-18-2016, 02:33 PM | #1 |
Seat options
Like to go with a split bench, something nice, for a 3100. Saw what was described as a "Tahoe 3rd row", looked nice.
What is popular? thx |
07-18-2016, 02:48 PM | #2 |
Re: Seat options
I used a 2006 Tahoe third row seat. It is in two pieces with built in three point belts and a center lap belt. The head rest is relatively low. I made a frame that allows me to use the tilt feature for access behind the seat and to remove the seats like the stock application. Here are some photos.
This is in a TF, AD is a little narrower, but I think it would fit find as there is room between the doors and and I left a gap in the middle for access to the drawer and area below the seat. Draw pulls out from under the driver. Stero is under the passenger side with a removable side panel too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-18-2016, 03:42 PM | #3 |
Re: Seat options
Thank you. Very clean install, nice fabrication
07-19-2016, 10:37 PM | #4 |
Re: Seat options
I have a mid 80's fullsize chevy bench in mine and it doesn't touch the doors. I think you should have plenty of options that you can make work.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
07-20-2016, 12:04 AM | #5 |
Re: Seat options
I put in a late 80's chevy truck bench seat in mine. I wanted the 60/40 bench but found it was to long from side to side for my 56 cab. would've been nice though.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
07-20-2016, 11:02 AM | #6 |
Re: Seat options
OrrieG- On the Tahoe seat, does it have any slide adjustment front to back or is in a fixed location? How is the width? I currently have an Astro van seat in my 57 and it is a little too narrow.
Thanks |
07-20-2016, 01:42 PM | #7 |
Re: Seat options
No adjustment stock seat is made to snap into brackets on the floor (see photo with brackets). I have a telescope column so I placed it as far back as I could and not bang on the back of the cab. I made the frame adjustable with pivot at back and threaded rod at the front so I can adjust it if the angle is not just right. If I remember correctly the top of frame is 5" off of the floor.
07-20-2016, 10:42 PM | #8 |
Re: Seat options
I also used 3rd row Tahoe seats. I used a universal seat bracket and slider from speedway. http://www.speedwaymotors.com/Univer...unts,2432.html To gain that independent forward backward slide. You would lose a complete easy fold out seat. However you still gain sliding ability to fold the back of the seats forward.
07-20-2016, 11:08 PM | #9 |
Re: Seat options
OrrieG- that is nice.!
Makes my 3rd row 02 safari seat look like poop . . . . But wait look..... Seat through there arm up look they approve . . . . . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
