Old 07-18-2016, 03:28 PM   #1
Rednek13x
Rednek13x's Avatar
Need help. Static drop inner fenders
Lowered my 83 c10 last weekend with a 4.5" front and a 8" rear and it dropped more than that in the front. It sits perfect but driving down the road and you hit a dip the front tires are smashing the inner fenders. I don't want to remove them, looking to cut them and tub them up just looking for ideas on how others have done it. My tires are 235/75/15
Rednek13x is offline   Reply With Quote
Old 07-18-2016, 04:52 PM   #2
SCOTI
SCOTI's Avatar
Re: Need help. Static drop inner fenders
235/75-15's are almost 29" tall (approx 28.8"). You're going to want to shoot for 27-28" tall max when dropping over 4".
225/70-15 = 27.4 (approx)
235/70-15 = 27.9
Get 2 new fronts & save the current tires for use on the rears @ a later date (or sell them/trade them/etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-18-2016, 07:08 PM   #3
bbbc10
Diggin The SquareLife
you can remove them an put in trailer fenders in or get some slosh tubz
bbbc10 is offline   Reply With Quote
Old 07-18-2016, 08:04 PM   #4
SCOTI
SCOTI's Avatar
Be advised, alot of water/debris makes it into the engine compartment on my Square body dually w/Slosh Tubs. While they work, they aren't as good as OE inners @ keeping water/road splash out.
Since I cut the inner structure out on my fenders for the install, my alternative is to modify them (extend several inches) which adds to the cost unless you're a fiberglass/body man.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-18-2016, 08:15 PM   #5
Rednek13x
Rednek13x's Avatar
I want to keep the tire size. I have a few ideas in my head but just looking for some other ideas.
Old 07-18-2016, 08:28 PM   #6
SCOTI
SCOTI's Avatar
There's a couple builds on here that have stretched their OE inners to allow additional travel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-18-2016, 08:53 PM   #7
Rednek13x
Rednek13x's Avatar
Do you have links or remember who's builds?
Old 07-18-2016, 08:56 PM   #8
chrismoore701
chrismoore701's Avatar
What about block inserts for the springs. Will stiffen the ride but should stop the bottoming out
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 07-18-2016, 09:24 PM   #9
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s...ght=wheel+tubs
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-19-2016, 10:34 AM   #10
GRADYS Performance
GRADYS Performance's Avatar
Would limiting the travel with different snubber height be an option?
GRADYS Performance is offline   Reply With Quote
Old 07-19-2016, 12:21 PM   #11
SCOTI
SCOTI's Avatar
Seems that would only change what hits what (@ least that's all it did for me).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
