07-18-2016, 06:18 PM | #1 |
Need Transmission Help
Hello all, I have a friend who has a '65 Chevy truck and needs a transmission. His truck has a 283 w/ a manual 3-speed on the tree. Our problem is a family friend took the old trans out, said it was no good and tossed it. So, we don't have the old one to use as a guide to find a proper replacement. Can anyone help? Thanks, Randy
07-18-2016, 08:24 PM | #2 |
Re: Need Transmission Help
A t5 would be a great swap
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
07-19-2016, 12:46 PM | #3 |
Is the T5 what came in it? Is there a way to tell?
07-19-2016, 12:49 PM | #4 |
Ok, found this:
http://www.ebay.com/itm/S10-T5-5-Spe...-/301983873788 Not the original, but that's okay. How hard would it be to mate this to the '65 283? Mate it to the manual column shifter? I sure appreciate your help! Randy |
07-19-2016, 12:52 PM | #5 |
A 3spd Saginaw is probably what was taken out of it. If you are wanting a bolt it replacement then I would try to find one they are usually plentiful and cheap...if if you are looking to upgrade there is a lot of good Info on here. Just depends on what ya want really
07-19-2016, 01:05 PM | #6 |
Okay bud, going off your recommendation for a T5, I found a shop here locally who can do it so I'm good to go! Thank you very much for your time and suggestion! The ol' 65 will be rolling again soon!
07-19-2016, 01:06 PM | #7 |
The shop gave some good suggestions for an upgrade, a couple of hundred more, but sounds very much worth it. The quoted $950 out the door.
07-19-2016, 01:30 PM | #8 | |
1. You will want to know what clutch package they used. 2. You will want to know what T5 they used and what the overdrive gear is. If they install a T5, it means you will have a floor shifter. If they do all the work for $950, I'm wondering if it's a rebuilt T5?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
07-19-2016, 10:56 PM | #9 | |
07-28-2016, 11:17 AM | #10 |
there are two types of t5's -- world class and non- world class. the world class is stronger. there are more than one bellhousing bolt patterns. some years/vehicle combinations that are the standard chevy bolt patterns and some are the ford bolt patterns. you will need a 1" spacer so that the input shaft will fit. the t5 input is longer than the standard chevy. there are mechanical speedo drives and electronic speedo drives. make sure you get the one you need. it depends on the year/model of donor vehicle. you will need a clutch disc -- 11" 26 spline from a chevy astro. maybe the driveshaft length needs to be changed.
I don't want to discourage you, but just some things to consider |
07-28-2016, 01:15 PM | #11 | |||||
I have been around T5s for a while, so I want to help clarify a few things.
Yes, the driveshaft will need to be shortened.
07-28-2016, 05:48 PM | #12 |
here is a page to find out a little about what trans should be in there , SM318
https://www.google.ca/webhp?sourceid...20transmission unless you know what you want to do with the truck I would just put a 318 in . you should be able to sell it again later if you don't trash it. it will be the least expensive way to get it going. it will be a bolt in which you can do as long as you get the right one. T5 trans are nice but will not take much abuse so if your friend is going to be a little heavy footed I wouldn't advise one. they will cost a lot more to fix. there is more than 1 way to install a t5. 1 you can go to the store and buy all the pieces to put one in or 2; if you have a few skills and can follow directions there is a little modifying to do and you can save yourself some money. if you need some links on how to do it yourself, I can supply them ron |
