07-19-2016, 08:55 AM | #1 |
Brake Booster Adapter
My C30 has power brakes on it from the factory, I suppose (I have seen this on other trucks as well). The booster is mounted to the fire wall using an adapter that kicks the booster at an angle to the fire wall. It also has a linkage that connects from the brake pedal to the booster rather than a simple rod. My question is why did the factory do this? Is it for clearance of the valve covers on the engine? Mine is in good shape, so I will reuse it- I am just wondering why the factory did this.
Might as well ask- if the booster is bad on mine, where can I get a repro version or an after market version that will work? I am going discs on all 4 corners. |
07-19-2016, 10:38 AM | #2 | |
Re: Brake Booster Adapter
"Life is too short to drive a boring vehicle". Later, Wayne |
07-20-2016, 12:09 AM | #3 |
60-66 Nut
I believe it was done for clearance for the I6 air cleaner. Check with your local auto parts supplier for a replacement brake booster.
07-20-2016, 10:58 AM | #4 |
Same here as others have said. O'Reilly had reman available just make sure it specifies w/ horizontal brackets.
