Will '73-'80 Frames fit on a '84?
Does anyone know how similar a 73-80 K20 frame is to that of a '84 K10?
I've always wanted to do a frame off resto on my K10 but want a clean rust free frame to start with. I came across aframe advertised as a 73-80. Will it be a direct bolt up to my K10?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
I'm just glad to be here!
Re: Will '73-'80 Frames fit on a '84?
Short answer is yes.
The front of the frame rails where the front bumper mounts will need to be modified to fit the 81-87 style front bumper.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
If you know of any threads with such detail please share. In the meanwhile I will do some more indepth searching Thanks!
Diggin The SquareLife
like said it will fit jus gotta trim the front of the frame where bump goes
Thanks for the added info. Just simply saying it needs to be modified leaves a lot to imagine. Trimming isn't hard at all, its adding material that takes real skill lol.
you don't have to add anything to the frame the 73-80 frame is round on the front an the 81-87 frame comes to a point
Here are some pictures that might help show what needs to be trimmed.
1977 front frame: ![]() ![]() 1984 front frame: ![]() 1981-1987 front bumper brackets: ![]()
I believe that the obround hole in the frame rail is in the same place on both years, you could use that hole to line up the later bracket to mark for the cuts and the additional holes that are needed.
Thanks for the pics!!!
