![]() Join Date: Feb 2004
2015 3/4 w/traler package
Does the brake controller move when foot brakes are applied and no trailer is connected? Or does it have to sense a trailer with electric brakes before it moves? Or does it never move unless it is pushed manually? The DIC shows gain adjustment from 0-10 and also a sliding bar I guess showing voltage to trailer brakes --the bar moves but no trailer braking,
I will recheck my trailer but it works as factory wired on my 2006. I have an aftermarket controller that moves with the braking --trailer or no trailer. I may have to take it back to dealer to look at.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Re: 2015 3/4 w/traler package
I have a 2014 Silverado with the factory installed brake controller. My guess is that the controller does not work until it "senses" a trailer is hooked up. The aftermarket controllers have no way to sense if one is hooked up. Larry
Re: 2015 3/4 w/trailer package
My trailer is a dual axle but only one has brakes and I read that the computer has to read enough resistance to acknowledge it has a trailer with electric brakes. I will hook it up again without the truck running and see what the DIC indicates. Supposedly one 12 volt bulb to ground on the trailer brake pin is enough to look like a trailer.
May try it if needed. tks
#4 | |
![]() Join Date: Nov 2004
I found this on another forum...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
No hydraulics -- just magnets electric. I hooked to my 2006 1/2 ton today and the trailer brakes function correctly hauling a 2001 s10 home in the rain. Next time I hook up to the duramax not running I will see if it sees the trailer. If not I will attempt a test with a 12 lamp.
I went dumb earlier when I asked if the manual button moved with the foot pedal but I know that only works if actually hooked into the hydraulic --like the old kelsey hayes types.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 07-28-2016 at 07:06 PM. Reason: words |
