Old 07-20-2016, 08:29 PM   #1
wshattuck
wshattuck's Avatar
Need Help identifying air breather/valve cover breather
here's what I got... my truck came with this air cleaner(see below) not sure if its factory or not? the lid doesn't cover the air filter completely(is that correct). also what I'm looking for is the PCV/vent tube from the passenger side valve cover to the air breather. the air breather has a small 1 inch square in it where it looks like something may mount into it from the valve cover?? also there is a metal tube coming out of the passenger side valve cover. any help would be appreciated....
thanks
wshattuck is offline   Reply With Quote
Old 07-20-2016, 09:41 PM   #2
geezer#99
geezer#99's Avatar
Re: Need Help identifying air breather/valve cover breather
One of these fit in the square hole. Held in by a clip. A short length of hose connects it to the metal tube.
http://www.lategreatchevy.com/full-s...1968-1972.html
Parts store should have what you need.
Old 07-20-2016, 09:49 PM   #3
custom10nut
custom10nut's Avatar
Could your breather set up be from a cowl induction hood from a Chevelle? To me, that's what it looks like
custom10nut is offline   Reply With Quote
Old 07-20-2016, 11:16 PM   #4
hdff
hdff's Avatar
Looks to me like someone lost the original air cleaner top, bought an aftermarket open air cleaner and used it in the original bottom. A cowl induction would have a rubber gasket around outer rim and no snouts.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 07-21-2016, 05:03 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Need Help identifying air breather/valve cover breather
Well I'm pretty sure it's not the stock housing for a truck.If you want to sell it, I'd be happy to buy it though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-21-2016, 10:23 AM   #6
wshattuck
wshattuck's Avatar
hey thanks Geezer... ill try and find one of those!
Old 07-21-2016, 10:44 AM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If that's an original GM dual snorkel air cleaner... it could be worth a bit of cash. Those came as a factory performance option on Camaro's and "A" body cars.
I had the factory original dual snorkel with a chrome lid off of my 1972 El Camino SS that I removed when I made a drag car out of it. Sold the car and still had some parts laying around. I put the dual snorkel on ebay for $50 bucks no reserve. Sold it for almost $500!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-21-2016, 10:49 AM   #8
wshattuck
wshattuck's Avatar
dang... how would I tell if its original?
Old 07-21-2016, 11:35 AM   #9
Andy4639
Old member
Andy4639's Avatar
Gary
Thanks!
Old 07-22-2016, 10:51 PM   #10
hdff
hdff's Avatar
thanks
from what I've found out there should be a spacer with a hose port off of it and a hose going to a flash suppressor that sticks into the pass valve cover where that pipe is. I pretty sure that that is not the correct air cleaner. here is a pic of mine with the hose going from the spacer between the carb and the air cleaner to the flash suppressor in the valve cover
"Wanda"
