Second opinions on transmission problems
I'm working on my '64 long step that has a 283 and a Muncie 3 speed with an r10 overdrive. I rebuilt the motor and trans winter before last, but the clutch was replaced 5 years ago so I didn't replace any of those parts except the pilot bushing.
Everything was sweet as cream for a couple of thousand miles, but then it went sour. Sitting at a light with a slight hill, light turns green, I let out the clutch and BANG! It felt like I had been rear ended. Not a shudder, but a single sudden bang. It happens with the clutch all the way out, not as it is let out. Grabbing the seat with my sphincter I ease iher back to the house, and it didn't give me any more trouble. I drove it a couple of thousand miles since, and the problem is random, but got worse and more frequent. I noticed the bell housing was wet with gear oil. So tonight I pulled the transmission expecting to see a dripping wet clutch disk. What I found was dry on the engine side, and a waxy scum on the transmission side. Here are the questions: 1. I've never had a clutch slip like that. Is that how a greasy clutch slips? 2. I think the 4 bolts that hold the front bearing carrier were the cause of the leak. I didn't put anything on them and the holes go through. Carrier has a new gasket and the slinger is also new. The return drain was lined up and clear. Possible over filled too. Any other possible causes?
1964 C10 Long Bed Step Side |
3 speed overdrive question
I'm pretty sure I over filled the transmission after rebuild and greased my clutch. The fill hole on the Muncie part is about the same level as the drain on the overdrive portion. I just now filled the gearbox, but left the fill plug out. Then filled the overdrive. In a short time the gearbox started puking oil.
Im sure they share oil, shouldn't they have the same fill level? It probably puked half a quart, which would easily put the level above the bottom of the bearing retainer.
*** That's interesting ***
Re: Second opinions on transmission problems
Yes a contaminated clutch can do that. But I'd also look for a sticking clutch linkage or a sticking pressure plate. If it sticks then releases violently, that's exactly what will happen.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#4 | |
![]() Quote:
I'm still not sure about the fluid level.
