Dash lights
Anyone know a good supplier or have recommendations on what bulbs to use? Mine are pretty burnt out.
Re: Dash lights
The bulbs are 194/168 any parts store will have them. If I were you though I would buy the 194 LEDs as they make a huge difference over stock and put less drain on the battery when you come to a stop.
Re: Dash lights
Awesome! Do you happen to know quantities of each?
Re: Dash lights
You have 5 lamps for cluster backlighting and an other one - for HVAC control panel illumination - that is on the same circuit.
Re: Dash lights
My 75 with no A/C used a different, smaller, bulb in the HVAC. Not sure what # it is though.
Re: Dash lights
Also, the LEDs are polarized so if some don't work just flip the bulb around 180 degrees.
Re: Dash lights
^this......after changing out each one turn on dash lights to see if led will light up....if not do what he said........
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
![]() Join Date: Oct 2014
Re: Dash lights
I also used led bulbs when I replaced all the bulbs in the cluster. It lights up nice at night. Also added led's under the dash.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
Re: Dash lights
Do you recall what PN led bulb goes under the dash? I believe the guage ones are 194s right?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
#10 | |
Re: Dash lights
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=191 And yes, the 194 are the gauge bulbs.
Re: Dash lights
i purchased the same set of courtesy lights (harness) that comes with 2 bulbs. Was going to install LEDs in there to see how it looks.
Thanks!
Re: Dash lights
Do the led's work with the dimmer switch?
#13 |
Re: Dash lights
#14 | |
Re: Dash lights
#15 |
Re: Dash lights
Here's that spec sheet I was talking about for all the bulbs. Hope this helps for any bulb reference you might need.
#16 |
![]() Join Date: Jul 2000
Re: Dash lights
Just be careful of cheapie LED bulbs. I'd go with Philips or Sylvania/Osram, because they are brighter and last longer than eBay specials. If you shop around you can save some money on a 2-pack.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#17 | |
Re: Dash lights
#18 |
Re: Dash lights
awesome,
thanks for that!!
#19 |
Re: Dash lights
What does a pack of 2 cost anyways?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
#20 |
Re: Dash lights
#21 |
Re: Dash lights
Thanks.
Had anyone sourced a LED dimmer?
#22 |
Re: Dash lights
Or $12.59 through Amazon with Prime shipping avaliable
https://www.amazon.com/gp/aw/d/B017V...ob_neva_mobile |
#23 | |
Re: Dash lights
#24 |
Re: Dash lights
maybe a little off topic but how are you guys/gals getting lenses (the clear part) so clean?
I've seen some of your dash cluster pics and they look amazing!
#25 | |
Re: Dash lights
LMC has them. They are not to expensive, but so worth every penny, when you can actually see clearly. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=76
