07-21-2016, 12:58 PM | #1 |
73-80 pulse delay conversion kits 2 left...
I have 2 of these kits left at the moment-delays have been tested, includes a conversion harness and a diagram. Must use 78-up motor and motor linkage arm. $90 shipped each just like the last batch!
73-77 sorry. |
07-22-2016, 12:02 AM | #2 |
Re: 73-80 pulse delay conversion kits 2 left...
Do you have a good delay module an switch for the 78 an up?
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-22-2016, 02:18 AM | #3 |
Yes I do....several in fact. $50 shipped if you'd like one!
07-22-2016, 07:18 PM | #4 |
Hey G
Do you have a pic of the conversion and harness? Thanks John |
07-22-2016, 08:33 PM | #5 |
Here's a pic...
07-22-2016, 08:37 PM | #6 |
This is a stock 1977 2-speed wiper motor....you need to change this out for a 1978-up motor....and the wiper motor linkage arm is different too-they don't interchange so you need to use a 1978-up arm/nut as well due to the threaded shaft on the 1978-up motors being slightly bigger-the pivot ball which attaches to the linkage arm assembly is the same for all 1973-87 tho.
07-22-2016, 08:40 PM | #7 |
On the same 1977 GMC High Sierra truck, here is the 1978 motor and new harness leads all tested and ready to go! In my lot I also provide instructions for swapping out leads on the cab side of the fuse panel bulkhead connector too!
07-22-2016, 10:04 PM | #8 |
Hello G
Con this conversion be changed to work with a vehicle with updated steering column with the wipers on the column. Thanks John |
07-22-2016, 10:22 PM | #9 |
Well the 84-up trucks have a different design where the stalk has the delay feature built in and there is a pulse delay circuit board integrated into the whole circuit too-not sure if it is even worth trying to make work ya know...? What year/type of wiper switch are you thinking about?
07-22-2016, 10:40 PM | #10 |
Yes please! Pm me the info, thanks!
07-22-2016, 10:40 PM | #11 |
Hi
I have a 71 chevy truck and I wanted to put a 84 chevy column in it. If you think this would work let me know. John |
07-22-2016, 11:11 PM | #12 |
07-22-2016, 11:12 PM | #13 |
07-22-2016, 11:35 PM | #14 |
Thanks G
If you come up with anything, please let me know. I would be happy to pay for one that would work on my 84 to 71 conversion. Thanks John |
07-22-2016, 11:37 PM | #15 |
Ok...I'm actually researching it now....I'll compare the two systems to see if I can come up with a plan for ya! If so, I'll bench test it using a prototype harness and we can go from there with a finished "kit" for ya!
07-22-2016, 11:42 PM | #16 |
That sounds great.
Thanks John |
07-23-2016, 12:08 AM | #17 |
PM me if you come up with something good.
07-23-2016, 02:44 PM | #18 |
Looking to put delay wipers on my 1982 c -20 . will these work ?
07-23-2016, 04:10 PM | #19 |
I have delay modules on hand w/o the conversion harness adapter for use on 73-77 trucks and these will directly swap out with your existing wiper switch! $50 shipped if you'd like one of those! PM me if interested!
07-23-2016, 11:01 PM | #20 |
Got my package thanks!!
07-23-2016, 11:04 PM | #21 |
07-24-2016, 12:32 PM | #22 | |
Just checking in to see how the research is coming along on my possible new harness. Thanks John |
07-24-2016, 08:41 PM | #23 |
Do you still have any of these left?
We have a 79 so I assume it would be a "plug and play" since it already has the correct motor. |
07-24-2016, 09:29 PM | #24 | |
07-25-2016, 07:27 AM | #25 |
I'll take one, sending PM
