Old 10-03-2003, 07:12 PM   #1
nu2-72
Anyone running Pro Comp A/T's
Looking into some tires. 315/75-16 with 16 X 10 Eagles.
Anyone running Pro Comps and what do you think of them?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-03-2003, 08:24 PM   #2
RANDY COX
RANDY COX's Avatar
Tires
I had a set on my Blazer 35's and they were great didn't have any problems they were rated for 40 thousand miles which i liked considering how much they cost,but BF GOODRICH are also good tires if you can afford them.Hope this helps you.Good luck.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 10-03-2003, 08:48 PM   #3
nu2-72
Thay are now rated 50k and looks like the web vendors are way up there. I will get them tomorrow.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 10-03-2003, 09:02 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
They are a great tire if you DO NOT WHEEL if you want to 4 wheel with them look for something else.. They have very thin sidewall's. I punctured a tire threw the sidewall on a stic, they did replace it but I would never run them agian..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-03-2003, 09:23 PM   #5
72chevyLWB
Got 20's????
72chevyLWB's Avatar
I'm running them on my 95 4X4. They are a very nice tire, but they will not last you 50,000 miles. Everybody that I have talked to has only got about 20-25,000 miles out of them. Mine are wearing fast too. And if you try to warranty them they will say that " We need all of your receipts from the shop you bought them, when they were mounted and balanced, every time that you rotated them and all the mileage from your vehicle when you did all that." They have their ways around it. Then even they will only Pro-rate them which means they will subtract what they are worth at that point from the cost of brand new ones. List price also, not cost if you work at a shop. So don't count on the 50,000 mile part.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 10-03-2003, 10:43 PM   #6
nu2-72
And who doesn't prorate items? As for wheeling, I don't do the dumb stuff, not much in the way of rocks here, and not much muddin for me. 40 miles per day of blacktop and I rotate trucks.
At $130.00 per tire, they are priced way below anyone else. This is not a daily driver either. Won't see 6,000 miles a year.
Throw in the 16" X 10" Eagle 589's and the tires, wheels, caps, lug nuts, mount and balance comes to just over $900.00.
I can't find anyone to beat that yet. Most are $400.00-600.00 higher on anything.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
