07-22-2016, 02:54 PM | #1 |
Measuring for a steering U joint
Hey guys I have a 73-87 collapsable shaft that I am putting in my 63 Pick up...I know the original Shaft end would be a 3/4 smooth for the u joint ..but not sure how you exactly measure a DD end for sizing..the flats on the shaft I have are 5/8" in thickness but did not see any 5/8 ends on the DD joints... ....thank you in advance..
07-22-2016, 07:58 PM | #2 |
Re: Measuring for a steering U joint
DD shafts go by the diameter rather than across the flats. Sounds like you're working with a 1" DD shaft.
07-22-2016, 08:50 PM | #3 |
that my friend is what I needed to hear...thank you i appreciate that..by the way your build is awesome!!
07-22-2016, 09:49 PM | #4 |
Thanks!
