Old 07-22-2016, 07:00 PM   #1
Orph58
Orph58's Avatar
Rearend?
I've been lurking for a while and this site is great,thank you all. Anyway,I have 64 with a 230/250. I'm putting a th350 tranny in her and wanted to know if the stock rearend(gear ratio) would be ok for a daily driver?. Sorry if this was addressed but I couldn't find it
Orph58 is offline   Reply With Quote
Old 07-22-2016, 07:40 PM   #2
vince1
Re: Rearend?
More than likely you have 3.73 and that is pretty slow for a direct transmission as a daily driver. I found a 3.07 and that is OK. A 700R4 would give you an overdrive which works better with the 3.73. I jack up one wheel and compare the driveshaft turns to one turn of the wheel to figure out the ratio. There are other ways like checking the code or counting teeth.
vince1 is offline   Reply With Quote
Old 07-22-2016, 08:04 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Rearend?
I had a 3.08 with a TH350 in my 61 and worked perfect as a daily driver. The only issue I had was on the highway.. At around 70 I was turning around 2500RPM. It was not too bad and I usually backed it down around 65.
Hope that helps.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-22-2016, 10:25 PM   #4
Orph58
Orph58's Avatar
Re: Rearend?
Thanks for the speedy replies.
Old 07-22-2016, 11:58 PM   #5
Captainfab
60-66 Nut
Re: Rearend?
The rear tire size will also be a determining factor in choosing the best rear gear ratio.
