Moderator
![]() Join Date: May 2007
NOS steering column parts, other small parts
Here are three NOS steering column parts:
1972751 NOS turn signal switch with horseshoe adapter 1993320 NOS neutral safety switch with install instructions 3959360(?) NOS shift indicator housing, non tilt column $125 shipped for the lot. I do not want to separate.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Jan 2007
Re: NOS steering column parts
Hey if you do decide to separate. I am interested in the neutral safety switch. Would also be interested in the e brake assembly you have acquired Thanks
Moderator
Still have this stuff, now $100 shipped for all.
Moderator
Adding these parts to the lot.
1394293- bushing kit 22501688- bushing 15538092- spring 15595063- cap? 15600380 x2 - spacers 1385607- swivel 1365182- lever These are small parts, some I recognize as transmission parts, others I'm not sure. Part numbers are there so you can check specific applications.
![]() ![]() Join Date: Jan 2005
Re: NOS steering column parts, other small parts
Do you still have any of these components? I'm interested in this one.
3959360(?) NOS shift indicator housing, non tilt column |
Moderator
Wow, can’t believe this thread is from 6 years ago!
I’m pretty sure I sold that piece a couple years back to someone that posted a WTB thread. I think I still have the NOS neutral safety switch and possibly the NOS turn signal harness/adapter. I’ve moved since then and am starting to get things pulled out and sold that I will not be using.
Ok. Thank you. It was a long shot, but I figured it was worth asking.
#8 | |
