Old 07-23-2016, 09:02 PM   #1
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
I stand corrected...Hooker 2455's do fit square bodies. Pics
So I finally realized that BBC and SBC clam shells are different. Replaced the worn out rubber mounts with energy suspension inserts and used the 1/2 inch taller small block clam shells. This raised the engine enough that the 2455's fit like a glove. I had to clearance the flange for the taller head bolts, and I had to clearance the left side clam shell. Other than that they slid right in. The fit is close in some places, but still plenty of clearance. Here are some pictures of multiple angles.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 07-23-2016, 09:04 PM   #2
Mr.Chevy4x4
Re: I stand corrected...Hooker 2455's do fit square bodies. Pics
Here are some pictures of some close areas.
Mike
Old 07-23-2016, 09:07 PM   #3
Mr.Chevy4x4
Sorry for the blurry pictures. I was trying to hold a light and take the picture. Hard to get a good picture under a dark truck. I know the tube looks close to that heat shield under the passenger floor board, but there is over a 3/8 inch of clearance.
Mike
Old 07-23-2016, 09:51 PM   #4
Jake Wade
Jake Wade's Avatar
They tuck up high also!
Jake Wade is offline   Reply With Quote
Old 07-23-2016, 10:25 PM   #5
Mr.Chevy4x4
Yep. They are only 3/4 to 1 inch below the frame.
Mike
Old 07-23-2016, 10:53 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
So many variables with mounts buckets, glad they turned out
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 07-24-2016, 07:13 AM   #7
Mr.Chevy4x4
Thanks, me too. I was getting pretty frustrated trying to figure out what I was going to do for exhaust.
Mike
Old 07-24-2016, 09:56 AM   #8
cadillac_al
So you need small block clam shells to make a big block fit correctly? That makes a big block swap a little easier.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
